Post your latest small engine oil change
1996 John Deere LX188 w/ 17HP liquid cooled Kawasaki
Out: Mix of leftovers I think, 15W40 & 10W30 HDEO
In: Mobil Delvac 1 5W40
Left the Supertech ST4967 on, usually change the oil once a year and filter every other year.
Murray rider
14 HP B&S OHV Commercial engine
Out: Pennzoil conventional 20w50
In: Amsoil Small Engine 10w40
New to me Toro 726 Snowblower.
Out: unknown fresh oil. About 30 min use with it.
In: RGT 5w30
I have a problem with putting in my own fluids with used equipment. Peace of mind. Used the foil form a funnel to keep it clean.
In: RGT 5w30
Instead of foil....take one milk/softener jug and cut/shape it into a funnel... ;)
Any thoughts on the T6 15w-40?
I haven't used it yet. I put mostly Rotella T 15w40/SuperTech 15w40 conventional in customer machines, and use T6 5w40 in generators. The synthetic is almost twice the price, so it's hard to justify the extra cost to most customers. It's also a bit harder to find around here. Tractor Supply here doesn't stock it, and the local WalMart is absolutely terrible at stocking oil. At some point I will try it for sure, I'm sure it's great oil. The T5 15w40 has been great the times I've used it.
Looking at my fall cleanup list, I could probably use the better part of a jug of that 15w-40 T6 between the harder working summer machines. Whatever is left could go in the jug that I use for bar oil on the chainsaw. So I am thinking that the lawn tractor, leaf vacuum and rototiller may see 15w-40 T6 this fall.
It should work well in all of those.
Gravely 260Z with Kohler Command Pro 27
Out: Valvoline Cummins Premium Blue 15w40/crappy Kohler filter
In: Delo XLE 15w40/Wix 51348
