Post your latest small engine oil change
craftsman 6.75 mower (B&S), replaced oil with Chevron Isosyn HDEO 15W40 after 1.5 season's of use.
All my other OPE equipments get the same treatment as well (15W40 isosyn).
Q.
Craftsman Push with B&S 6.25 engine:
-Supertech 15w40
-< 1oz. Mos2
Hadn't done an oil change on this since November 2010 but it doesn't see heavy usage by any means.
1999 Simplicity riding mower with Kohler 14HP single cylinder gets Mobil 1 10w30 in the engine and Mobil 1 Extended Performance 10w30 in the hydrostatic transmission.
1999 Simplicity walk behind snow thrower with 10HP Tecumseh gets Mobil 1 5w30.
Older Ariens walk behind mowers with B&S engines get whatever SAE30 small engine oil is on sale at Farm Fleet when it's time for a change.
Toro Recycler with with Briggs & Straton engine.
And a "Golden Boy" walk behind edger with an ancient Briggs engine.
It gets hot here, and the edger has seen better days, so
Both 1 pint of 5w40 Maxlife.
2012 Craftsman YT 4000 lawn tractor. Purolator 10241(automotive) filter, 10-30 Penz platinum syn oil.
My father in law bought a new generator and gave us his old Colman 4000watt generator with a Tecumseh engine. Put in a little bit of everything, about half a quart of Quaker State Ultimate Durability, little bit of castrol gtx 5w30, and a little bit of g-oil sae 30. runs good, just wish it had a quieter muffler, and a bigger gas tank
2005 Briggs & Stratton Quantum Edge 6.5HP
Out: Unknown
In: 10W30 Valvoline SynPower SN
Replaced the spark plug RJ19LM, and seafoamed the cylinder head and chamber.
changed oil in my 22 hp Briggs and Stratton endurance engine on Husqvarna rider with Castrol Syntec 5w30 and new briggs filter.
5 hrs on my new Chonda`212cc: the oil was a grey green with sparkly little highlights.
Had an extra bottle of Honda 10-30 that Home Depot thru in when I bought my Honda mower.
Seized (Only Piston Rings, little DW40 lossened right up)2009 Briggs&Stratton 6.75 Flathead on Craftsman pressure washer(Now on my Ranch King Lawnmower) Out probably Craftsman 30 Sieze oil, In 50% SuperTech 5w-20 and 50% Accel ND30. Works, Runs like a Champ, and has used maby, barely 2 ounces over the past year!
Weed Eater 20" Push Mower
Out: Black Swill/Unknown. Had not been changed in 5 yrs. Probably 50 hrs of use over that time.
In: Castrol GTX High Mileage 10w30
2013 Honda HRX217
Out, first fill Honda 10-30
In: Quaker State Ultimate Durability 5-40 Euro that I found this weekend at Big Lots. They 4 qts @ $4 each.
2013 Huskee 4200 42" tractor Powermore 4200cc
Out: Valvoline Premium Blue 15w40 Wix 51516
In: Pennzoil Conventional Napa ProSelect 21516
