Post your latest small engine oil change
Echo Bearcat WT190
Out: Factory Fill 30w
In: Mobil 1 5w30
Cub Cadet LT1046
Out: Pennzoil Conventional 10w30
In: Quaker State Ultimate Durability 10w30
Husky with Honda GCV 160 Drained out Valvoline 30 wt put the same back in . Kid is about to be pushing it around when he gets home . This mower has been trouble free except for the choke . Cant say the same for the kid , starting to think he needs a good choke .LOL .
2010 Craftsman Briggs & Stratton 550e Silver Series 158cc
Out: Briggs & Stratton SAE30
In: 10W30 Castrol Syntec SM/SL
Replaced the spark plug RJ19LM, air filter, sharpened the blade and seafoamed the cylinder head and chamber. It's what good son-in-law's do.
1999 Stanley Power Plant 6.0HP Tecumseh LV195EA
Out: Pennzoil Conventional 5W30
Replaced the spark plug RJ19LM, air filter, sharpened the blade and seafoamed the cylinder head and chamber. Start first pull, every time!
New John Deere D140 Lawn Tractor
Out: Factory fill at 8.8 hours
In: Trop Artic 10w30 SM
Plan to change again at end of season with Motorcraft 10w30 SN
Briggs & Stratton 725ex (4.5 hp)
Out: factory fill
In: Rotella T1 SAE30
Replaced RJ2YXLE plug with RJ19LMC
Changed my GCV160's oil this weekend as well. Pennzoil Ultra 10w30 on the way out and in. I've had auto choke issues as well.
--Matt
Early 80s 3.5HP B&S engine on a Snapper bagger lawn mower.
Out: Mobil 1 5w30 (in for 2 seasons). Came out still fairly clean.
In: Pennzoil Platinum 5w30.
Also installed a new OE replacement blade.
2004 model Briggs 5.5 hp on a Huskee 22" Mulching walk-behind mower (re-branded MTD I bought at Tractor Supply).
Out: ST 30w
In: 17 oz. Kendall GT-1 synthetic blend 10W30 combined with 3 oz. Pennzoil Conventional 10w30
New blade
New air filter
Cleaned and re-gapped spark plug
Mower started right up on the first pull and purred like a kitten while cutting the grass for the first time this year. I will use the rest of the Pennzoil conventional quart for topping off during the season.
Drained the last seasons oil out of my briggs quantum mower engine. Refilled with 50/50 mix of Napa synthetic and Super Tech 5w30. I guess that would be a syn blend, right?
2010 cubcadet push mower 173cc engine
Out: Supertech conventional 10w30
In: Oil from my leftovers jug, combo Super Tech 10W30, delvac 15w40 and some Citgo 10w30
1991 TORO 5HP 22" Self-Propelled Lawn Mower
OUT: AMSOIL 10w30 Small Engine Oil
IN: 1/2 AMSOIL 10w30 Small Engine Oil & 1/2 AMSOIL 10w40
4-Stroke Marine Oil (as I ran out of the Amsoil Small Engine oil)
1999 John Deere F510 with Kawasaki 14hp motor.
The total capacity is 4 quarts but the hydraulic unit shares the oil. Though it does not mix somehow. I just drain out 2 quarts and change the filter. Then the old motor oil goes into the hydraulic unit. Only 2 quarts will drain. The motor oil is
lighter color than the hydraulic unit oil.
I use to drain two then pour two which drove out the motor oil but quit. The oil stays good looking all year.
2 qts Valvoline synthetic 5w30. Purolator Pure One PL10241 filter
Just bought a 1991 MTD "Turf Power" tiller. I bought it from the original owner who purchased it new from Agway in 1991. It was stored inside and hardly used. He also included all the paperwork. I'm not a fan of MTD stuff, but this seems fairly well-made. I think their stuff from the late 1980s/early 1990s was of much better quality.
It has a 5hp Briggs and Stratton flathead engine. I changed the oil to Rotella T 15w40, installed a new air filter, and a new spark plug.
Here is a pic of it:
I think it needs a carb cleaning since it is surging at full throttle a bit.
