Very good sir. I stand corrected @AutoMechanic. Thanks to the folks that know alsoIt doesn't, it's a hydrocracked petroleum basestock blend. I asked Shell tech support recently and they said no GTL in Pennzoil High Mileage.
Yeah, I'd say this is supported by the SDS which doesn't even list a CAS # for the base oil.It doesn't, it's a hydrocracked petroleum basestock blend. I asked Shell tech support recently and they said no GTL in Pennzoil High Mileage.
So elaborating on what cheese puffs said; if it’s hydrotreated is it then considered blend?Yeah, I'd say this is supported by the SDS which doesn't even list a CAS # for the base oil.
I mean that the "synthetic" portion of the blend (whatever percentage that is - don't know) is hydrocracked/Group III oil.So elaborating on what cheese puffs said; if it’s hydrotreated is it then considered blend?
No.So elaborating on what cheese puffs said; if it’s hydrotreated is it then considered blend?
I did not know that, that's actually super interesting. I thought hydrocracked = Group III.No.
Most (but not all) modern Group II/Group II+ base oils are hydrocracked bases, just like Group III. They just don't have a high enough VI to be called Group III, so they aren't labelled as synthetic, even though they are produced in the same way.
If the engine isn't too close to the frame I'd just use a ph3614 or fl910s instead of the overpriced Kohler filter.View attachment 146939
Heading to grandmas to change the oil in her Toro zero turn mower. Got these two quarts of Castrol 10W-30 oil and this Genuine Kohler filter and a spark plug $37 out the door at Lowe’s. I hate she has a Kohler engine but oh well lol. Castrol is one of my preferred oil brands. Way cheaper than Toro oil too.
I’ll check and see. They didn’t have either of those at Lowes however I did bring a PH4386 with me in case. Could not find which filters would cross with this one so I just had to get the one I knew would work. I do like that idea though. This filter $19 itself.If the engine isn't too close to the frame I'd just use a ph3614 or fl910s instead of the overpriced Kohler filter.
That's why it's hilarious when folks like @AutoMechanic are dead set on avoiding "synthetic" (read: Group III) oils and only want to run "conventional" when the reality is that a modern Group II/II+ is produced in the same manner as a modern Group III, it just isn't processed enough to yield a VI high enough to make the cut to be labelled as Group III. This also reduces production costs which is why Group II(+) bases like Mobil's EHC are a great low-cost blending option for grades like 10W-40, as they offer a ton of bang for your buck.I did not know that, that's actually super interesting. I thought hydrocracked = Group III.
ExxonMobil said:In June 2016, ExxonMobil broke ground on the construction for the new hydrocracker at the company’s Rotterdam refinery. The unit will upgrade heavier hydrocarbon byproducts into cleaner, higher value finished products such as EHC™ Group II base stocks and ultra-low sulfur diesel.
Group III base oils are greater than 90 percent saturates, less than 0.03 percent sulfur and have a viscosity index above 120. These oils are refined even more than Group II base oils and generally are severely hydrocracked (higher pressure and heat). This longer process is designed to achieve a purer base oil.
Cheaper to manufacture while offering great performance. Mobil has really done an incredible job in this space and their EHC bases are probably "best in class" offering Group III-level performance in many areas at a more attractive price point.@OVERKILL what's the biggest draw with Group II, lesser cold flow? I just switched to Pennzoil High Mileage blend in my car from Platinum HM because I don't run extended intervals (been running 6,500 miles, just did a 5,200 though) and I was thinking about sticking with blends for three seasons a year and then running synthetic just for winter for cold start ability.
Coldest start I had this winter was -6F. Oil weight will be 5W-30 either way. Does that sound like a decent plan, switching to Platinum for the GTL cold flow properties, or does it not even matter?
Yup, solvent refined Group I and II products are not overly common now. Group II in particular is almost exclusively a hydrocracked base at this juncture.More about base oil and basics about their refining.
https://www.machinerylubrication.com/Read/29113/base-oil-groups
Basically, Group III oils go through similar refining steps as Group II, just more finishing to produce more uniform molecules and fewer impurities.
I actually wanted to switch to Mobil Super (used to use it a lot a handful of years ago) but it seems like they don't even make it anymore or at least it's really difficult to find? Why does XOM put so much effort into Group II then, is that to sell to private blenders, or is that all for Delvac and to use as an additive carrier in the Mobil 1 line?Cheaper to manufacture while offering great performance. Mobil has really done an incredible job in this space and their EHC bases are probably "best in class" offering Group III-level performance in many areas at a more attractive price point.
As long as you are using an oil from one of the majors that meets the performance requirements, you'll be fine, so, nothing wrong with your plan.
That one is pretty much just a stubbier version of the 3614/fl910 size filter, if you have the space might as well use the bigger passenger car filter but sometimes they put the engine in the unit in such a way that you get stuck with the over priced stubby thing and it doesn't matter wether you buy the one with the Manufacturer's name on it or a more generic Fram, Wix/Napa, Purolator, etc filter those stubby application specific filters all cost like $10+.View attachment 146939
Yeah, their EHC bases are a very popular sell to other blenders, including Shell.I actually wanted to switch to Mobil Super (used to use it a lot a handful of years ago) but it seems like they don't even make it anymore or at least it's really difficult to find? Why does XOM put so much effort into Group II then, is that to sell to private blenders, or is that all for Delvac and to use as an additive carrier in the Mobil 1 line?
One of the weirdest thing I noticed recently is the the 5W20 and 5W30 grades of Valvoline Maxlife+ (the 150k black bottle) are mostly solvent refined oil. The one says extended protection but it is the right SDS for the part number and the file name of the datasheet contains "VAL EZ HIGH MILEAGE 150 "Yup, solvent refined Group I and II products are not overly common now. Group II in particular is almost exclusively a hydrocracked base at this juncture.
Leave it to Valvoline, lol.One of the weirdest thing I noticed recently is the the 5W20 and 5W30 grades of Valvoline Maxlife+ (the 150k black bottle) are mostly solvent refined oil. The one says extended protection but it is the right SDS for the part number and the file name of the datasheet contains "VAL EZ HIGH MILEAGE 150 "
