June 1st picked up 2 X 5 quart jugs of Mobil 1 EP 5W-30 at Walmart and submitted the $10 X 2 rebates...
Bill
Bill
Didn’t even know they had this. Will buy some today!June 1st picked up 2 X 5 quart jugs of Mobil 1 EP 5W-30 at Walmart and submitted the $10 X 2 rebates...
Bill
You need help Brother.![]()
that's only a partial list...Walmart should self populate after placing a "W" in the field for retailer on the rebate form (online at leastDidn’t even know they had this. Will buy some today!
Edit: For some reason Walmart is not on their list though, and Walmart is still cheaper without the rebate than advance auto, or autozone
Unfortunately when I access the online link through that site it doesn't work thoughthat's only a partial list...Walmart should self populate after placing a "W" in the field for retailer on the rebate form (online at least)
https://bobistheoilguy.com/forums/threads/the-not-so-great-mobil-1-rebate-of-2023.369271/
Bill
What Wal Mart did you find 5gal jugs ST for $19~ each?Two 5 gal jugs Super Tech 5w20 full syn on rollback for $19.98 each.
Two FL-820S filters at Rural King for $4.99 each.
Kingsport TennesseeMart
There is some efficacy to not mixing brands, while all oil should be miscible the anti oxidant chemistry may very between brands and mixing them may result in an oil that no longer meets the manufacturer approvals, like if you follow the long drain intervals on modern heavy duty trucks it's best not to mix brands or only mix brands as top up towards the end of the oil change interval.View attachment 160545
2.5 gallons of this Mobil Delvac Extreme. Walmart for $52. Dad seen it has high temperature protection and his truck runs a little hot so he is trying to see if this can help. He said you can’t mix oil brands though so I can’t put this in with Rotella and I was like yeah you can why couldn’t you? He said it will mess with the additives in the other brands I said dad that’s not true and I pulled up a whole search history worth of “can you mix oil brands” here and showed him lol. So now he is going to mix them lol. He has been watching too much YouTube lol.
I see. He doesn’t do long intervals. Hopefully this will do no harm. These all meet the Caterpillar approval.There is some efficacy to not mixing brands, while all oil should be miscible the anti oxidant chemistry may very between brands and mixing them may result in an oil that no longer meets the manufacturer approvals, like if you follow the long drain intervals on modern heavy duty trucks it's best not to mix brands or only mix brands as top up towards the end of the oil change interval.
Man, what kind of pricing did you get on these different oils? The Tractor Supply stores I visited in late April-early May were skinny on clearance oils.
The secret is to keep your pinky finger high when pouring. That cancels out any unwanted negative additive interactions.I see. He doesn’t do long intervals. Hopefully this will do no harm. These all meet the Caterpillar approval.
