Post your latest oil or filter purchase
5quart jug of Valvoline Extended Protection High Mileage 5w30 and a white can ST 3387A filter. Will cut that and ancient champnlabs made on Lockasim sent me later.
Valvoline Extended Protection High Mileage tells me you're a connoisseur. Is it for a Studebaker? Pardon if that's a dumb question. I don't know what viscosity is appropriate for a Studebaker.
Walmart made an oopsie and mislabeled Delo XSP as Delo XLE SB so I scored 3 gallons for half price but it was only for this box. I did check both 6 quart boxes by removing the caps and saw that both pull tabs were still intact and the oil looked new. It's only missing the outer box which houses the two inner boxes.
For grandmas mower. She has a Toro Titan ZX5400 zero turn with the Kohler Confidant 747cc. I love doing maintenance on it. The Kohler filters are ridiculously expensive so I just go Fram and my preferred oil which is Castrol. It’s enough for two years because the capacity is around 2.5 quarts so I just need a new filter next year and will have 2.5 leftover.
2x Supertech ST10246 filters for the 1.6 diesel Cruze, compared to the acdelco pf2257g they look about the same quality, Supertech in my opinion being a little higher quality, with more even pleat spacing, and e core, the ACDelco doesn't have any center support structure. Supertech $2.97, acdelco $8.98
The capacity is 2.0 quarts.
The FRAM TG3614 or Super Tech ST3614 are decent filters for this engine.
Latest Amsoil haul. Picked up some ULV ATF and signature gear oil for my 10 speed 24 Sierra 5.3L PPE pan project. Couple oil changes worth of XL 5w30 to try out in the 21 Outback 2.5L. Finally 3 hole oil change v-twin 20w-50 alongside their dedicated Primary and Transmission fluids with filter for the 04 twin cam Harley.
3x 5qt Valvoline Restore and Protect 0w-20, 1x 5qt Valvoline Restore and Protect 5W-20. I had some WM gift cards.
Closest WM by me had the one jug of 5W-20 (on top shelf backwards) and no other Valvoline Restore and Protect 5qt jugs any viscosity. Some of the other WM's I basically pass on way home from work showed no stock, any versions.
The one closest to work showed 10x 5qt 0W-20. Shelves had nothing. Store stocker person checked in back and found the 3 jugs of 0W-20 said that was all she could find.
