12 single quarts of Shell Rotella Gas Truck 0W-20 from Advance Auto Parts @$2.50/qt plus 20% off discount code. Too bad the RGT rebate doesn't work at AAP.
Just curious, why would you return RGT that you got for under $2/qt?I picked up some Rotella Gas Truck 5w30 (5 qt jugs) and 0W-20 (single qts) from Advance as well. They are clearing out old stock and the oil is from 2018 based on dating info on bottles. Can you check your bottles to see if you received newer stuff? I called them and they are willing to accept return, but not sure it is worth it for the average of under $2 a quart (I had a 25% off coupon). TIA.
The cost is not the issue by itself; the GF5 vs GF6 coupled with the age, is slightly the nagging issue. I have lawn mowers, generators, 4 stroke Honda weed-whacker and edger, and a bunch of other lawn and garden equipment, plus the autos, and will use these up. Not worth returning it. It is good oil and I have been using it in my Titan for the past 3 oil changes. I called ADP to see if they had newer stock, they said no new stock, all they had were older stock they were clearing stock, but they was nice enough to offer the return. Will keep.Just curious, why would you return RGT that you got for under $2/qt?
I ended up buying more of this after all the rebates it'll have been less than $30(well really about $70 factoring the tank of gas) for 24 jugs, got 15x 5w30 and 9x 5w20. Only like $3/jug if you factor in gas.5x 5qt jugs of 5W30 RGT
3x 5qt Jugs of 5W20 RGT
If my shell rebates go through, since I bought them at TSC on price match, It'll be just under $10 for the 8 jugs including tax
