6 liters Liqui-Moly Top Tech 6200 (VW 508.00/509.00)
1 Hengst oil filter
1 VW drain plug
1 Hengst oil filter
1 VW drain plug
I see you ran VPBR in one of your vehicles? What do you think?That must have cost you a pretty penny.
Make sure to submit your cashback3 jugs of Valvoline HM 5w30 at Walmart.
Minimal impact.I see you ran VPBR in one of your vehicles? What do you think?
I found out about Valvoline "Restore" when doing research here 4 yrs ago because of a vehicle we had recently purchased with an oil consumption problem.
Almost 4 yrs ago our new to us 2007 GM Yukon Denali w/all aluminum 6.2L had stuck rings, caused by 130k miles with a poorly designed pvc system in the driverside valve cover. I quickly discovered a GM TSB which involved a valve cover change and a piston and combustion chamber soak. I did these and all has been well for the last 4 yrs and 50k miles.
In before lock.Waiting for the results of the latest UOA for our Yukon. If the FE isn't normal I'm gonna try this.View attachment 114080
What's your reasoning for adding 2-quarts of EC and why use Lubequard, or any additional additive for this process?
2 qts of the EC b/c my W8 is a 9qt engine...just rounding up a bit following their 1:5 dosing recommendation. The Lubegard is for the auto trans.What's your reasoning for adding 2-quarts of EC and why use Lubequard, or any additional additive for this process?
