Post your latest oil change
I suppose DSG fluid is oil too.
2010 VW Passat wagon 2.0T/DSG 160ishK
Out: 4.7qts. Pentosin G052182A2, Hengst EG218HD320 (made in Taiwan!)
In: Same.
Beer: 36ozs Wicked Weed Perni-Haze IPA (fluid was top fill, took a while)
Cigar: Liga Privada No. 9 Flying Pig
We have a cigar thread for pics, just sayin' :ROFLMAO:
Yes, yes I know (posted a couple).
Here. Just for you. I have another one left 😁
New to site, posting changes from February:
OCIs for wife's Honda and my truck are every 5K miles or every 5-6 months, whichever comes first.
2019 Honda CR-V 2.4L FWD, 54K miles, replaced all washers for oil and transmission change as well.
  • Oil Change:
    • Out: Valvoline Advanced 0w-20, Honda OEM Filter AO2 (4.6 quarts)
    • In: Pennzoil Ultra Platinum 0w-20, Honda OEM Filter AO2 (4.6 quarts)
  • Transmission Drain & Fill:
    • Out: Factory Fill
    • In: Honda HCF-2 Transmission Fluid 3.9 Quarts
  • Cabin and Air Filters
    • Out: OEM filters
    • In: OEM Filters
2022 Ram 1500 Sport 5.7L Hemi, no-etorque, 4x4, 33K Miles
  • Cabin and Air Filters:
    • Out: OEM
    • In: Purolator filters (switched based on Project Farm's video)
  • Oil Change:
    • Out: Mobil 1 Extended Performance 0w-20, Wix Filter (7 quarts)
    • In: Mobil 1 Extended Performance 0w20, Mobil 1 Extended Performance Oil Filter (7 quarts)
      • This will be my last time using Mobil 1, will send UOA and VOA to Blackstone on next OCI. (I have an unopened quart of Mobil 1 Extended Performance, goal is to establish a baseline). Going to use PUP for next 2 OCIs, compare results, then probably switch over to Valvoline Restore and Protect or Redline 5w30 (warranty will be over at that point) .
      • Oil filter has been ok since change, but planning to switch to Micorgard select on next OCI, if I like that filter then I'll make a nice sized stock pile.
  • Oil Change:
    • Out: Factory Fill
    • Out: OEM filters
    • In: OEM Filters
    • Out: OEM
  • Oil Change:
Welcome to the site!
Uncles 2014 GMC 1500 4.3 DI V6
121,xxx miles
ST syn 5W30, Pentius PLXL 10575 filter
He does not maintain it like he should, he lets the OLM flash for months at 0% before he lets me know it needs an oil change. I used to worry about it but does not pay to lose sleep over it. Last had an oil change at 110k with same oil and filter. Despite the abuse it runs well.
2023 Mazda CX-50 2.5S
OCI was 9831 miles and 312 hours. The OLM was showing Change Oil Soon and 600 miles remaining for about the last 500 miles.
Oil Out: Pennzoil Platinum 0W-20
Oil Filter Out: 1WPE-14-302
Oil In: Pennzoil Platinum 0W-20
Oil Filter In: 1WPE-14-302
Oil sample was taken and will be posted when its available.
Noticed an oil leak during the change, so it will be going back to the dealer to get that looked at. So this specific run will probably be quite short since it appeared to be the oil pan leaking.
2008 Chevy Malibu w/ 2.4L Ecotec ~110k mi
OCI: 2k mi and 6 or so months
Out: 5W30 PP High Mileage
In: Mobil 1 15W50
Kept the Fram Ultra XG9018 filter in just cracked the housing let it drain back and screwed it back in. Going 6mo now as the short trips seem to be really bad on the oil in this car, replaced a VVT actuator and a sensor last year and there was some nasty sludge build up around the sensor so I think the annual oil changes aren't enough for it getting driven only a couple miles each way a few times a day. Went with 15W50 since I'll change it again in the fall and I have more than enough of it to spare from the 2021 Walmart extravaganza.
A couple of oldies that haven’t left the yard in 20 years;
1973 Chev crew cab 3+3 3500 with a rebuilt 350 10:1, .0025” rods and mains, hyd ft 244/252 @ .050 116 LSA.
Out: 20 year old Duron 15w40 and PH373 extra long filter.
In; Walmart SAE 40, I bought a pail on clearance for $10 five years ago. TG5 filter.
1986 GMC 1500 with a rebuilt 307, 9.7:1, 208/214 hyd ft @ 108LSA, 1.94/1.6 valve 305 heads, 1.6/1.5 rockers.
Out; 20 year old 10w30 Duron and ph373 filter.
In; Duron 15w40 and ph373 filter.
2017 Subaru Crosstrek FB20 (72,016K) Good Friends
Out: Amazon Basics HM Synthetic Blend 5W30 SP & OEM (1726 miles)
In: 5 quarts of Quaker State High Mileage Full Synthetic 0W20 SP & ST6607
Note: What I have read on here about the FB20 & FB25 engines is they are hard on oil. 4K OCIs is what it will get moving forward.
