This coming week. Gotta put the order in and sch.New tires today?
That's ridiculous. There is nothing about that statement of yours that is rooted in data or proof.It’s not misleading at all. You just don’t want to accept it because it goes against your own opinions.
We’re going to have to agree to disagree about this then. I’ve been here a heck of a lot longer than you….That's ridiculous. There is nothing about that statement of yours that is rooted in data or proof.
It is not my "opinion" that different engines and driving conditions present different challenges for an oil, and that there are plenty of use-cases where Amsoil at 10k miles will not fair better than Supertech at 5k. My "opinion" is that "it depends", and you're unable to accept that, why, I don't know.
Pulling the "I've been here longer" card has nothing to do with the basis of your statement, but alright.We’re going to have to agree to disagree about this then. I’ve been here a heck of a lot longer than you….
Please keep us posted on the Valvoline Restore and Protect testing.Badly designed low tension oil rings are the real problem, but combining that with low quality base oils is a bad combo IMO. Quality oils with high solvency seem to produce pistons well cleaner than industry standards even at longer oci’s. Lower quality oils start leaving behind piston deposits from the start and I’m not sure shorter oci’s will prevent the inevitable. 5k oci’s didn’t work for me. Now if Valvoline Restore and Protect works as claimed it’s a game changer because of the cost vs boutique oils. Only time will tell….I’m testing those claims now.
In about 3200 miles I’ll be done with my 4th oci and will post my results.Please keep us posted on the Valvoline Restore and Protect testing.
One thought I had is that the oil control ring design issues which I assume causes oil to over heat and not flow properly though the drain holes in the piston, might get gummed up regardless of whether regular group III, or GTL, or PAO, or Ester based oil is used due to the excessive high temperatures at the piston rings, as they are extremely close to the combustion chamber. Put simply, expensive oil may not be able to handle the extreme temperatures due to a poorly designed piston ring drain hole design, and have an identical result as regular group III synthetic.
Using an oil with some cleaning capability like Valvoline Restore and Protect or group III + HPL Engine Cleaner 30, or HPL PCMO could be a way to mitigate this.
What brand did you replace it with?the old flex pipe between the manifold flange and converter broke.
No, but a group one like Delo 400 SAE 30 or 40 will.Would a GTL, PAO, or Ester based oil excel at keeping piston rings clean instead of just using a regular group III synthetic?
So PAO based oil (Amsoil) and GTL based oil (Pennzoil Platinum) seem to have similar performance in extreme heat, and Pennzoil advertises that it's platinum oils keep piston rings 40%+ cleaner than industry standards. The GTL from natural gas oils from Pennzoil are very good in extreme temperatures. So, perhaps a low cost long term solution is to use Pennzoil Platinum High Mileage Full Synthetic oils with HPL Engine Cleaner 30 in the 1:5 ratio for every 5k OCI going forward. Just a thought.In about 3200 miles I’ll be done with my 4th oci and will post my results.
I can say I have a friend with the same engine I have in my Outback. He has used AMSOIL Signature Series in it since new. He has around 110k on his and burns no oil. Mine started burning oil at 60k miles. It’s not scientific by any means but gives me hope.
I do agree it’s very vehicle and condition specific. Obviously a Hyundai with scored cylinders is doomed. That design was doomed since day one.
A-Premium from Amazon. It fit well, and the catalyst temp and upstream and downstream O2 readings were all good when I was monitoring it with my code reader while he drove it. Smelled like a new car with rotten eggs once we got on it hard.What brand did you replace it with?
Someone smarter than I will have to answer your question. From what I’ve read the solvency is a key factor as well as heat resistance. Amsoil has a good slug of ester too. Maybe that Pennzoil combo would do the trick?So PAO based oil (Amsoil) and GTL based oil (Pennzoil Platinum) seem to have similar performance in extreme heat, and Pennzoil advertises that it's platinum oils keep piston rings 40%+ cleaner than industry standards. The GTL from natural gas oils from Pennzoil are very good in extreme temperatures. So, perhaps a low cost long term solution is to use Pennzoil Platinum High Mileage Full Synthetic oils with HPL Engine Cleaner 30 in the 1:5 ratio for every 5k OCI going forward. Just a thought.
Got a bunch of Italian Tune-Up episodes in there too?In about 3200 miles I’ll be done with my 4th oci and will post my results.
Lots of people report oil consumption going down with Valvoline Restore and Protect, so most likely it's getting stuck rings loose so the oil control rings can work properly. If any of my vehicles started using oil, I'd be trying out some Valvoline Restore and Protect as that's about as easy of a fix attempt you can perform.Using an oil with some cleaning capability like Valvoline Restore and Protect or group III + HPL Engine Cleaner 30, or HPL PCMO could be a way to mitigate this.
Anxiously awaiting the cut open fikter. Nice work too sirCoworker's 2010 Chrysler T&C 3.3 V6, 168,000 miles now
3 months 2800 miles, Out: Shell Rotella T4 Protec WIX PXL51515
In: same
Also replaced catalytic converter, topped off coolant, lubricated doors, adjusted tire pressures. it's a lot quieter now and runs much better with the new catalytic converter, the old flex pipe between the manifold flange and converter broke.
Beautiful wheels. And no curb rash!‘23 Toyota Sienna XLE Hybrid
32,380 miles / 4,780 miles OCI
Out/In: Pennzoil Platinum 0W20 / YZZN1 Filter
Off: Factory Lug Nuts
On: White Knight Chrome Plated Lug Nut 12 mm x 1.50 Lug nuts NEA 153074
Took advantage of the sunshine and warmer temp. Preemptively replaced all the factory two piece lug nuts with single piece. Some of the factory Yokohamas are looking pretty rough. I’ll be picking up some new tires at DT real soon.
I think they are pretty sharp looking. That isn’t from a lack of my wife trying lol. Probably where the gash in the sidewall came from. Low pros would have hit the wheel for sure. I’ve learned over the years not to get low pros on my wife’s vehicles.Beautiful wheels. And no curb rash!
My filter pliers crushed this one. I cut it open to drain it but couldn't get the filter element out. Looked fine from what I could see though.Anxiously awaiting the cut open fikter. Nice work too sir![]()
Good to hear sirMy filter pliers crushed this one. I cut it open to drain it but couldn't get the filter element out. Looked fine from what I could see though.
