Post your latest oil change
2006 Toyota Prius, ~118K miles
Out: 2 qts PU 5w20, 1 qt PYB 5w20, ~3/4 qt PYB 10w30 & Wix 57145
In: ~3.5 qts NextGen MaxLife 5w30 & Wix 57145 @ 5551 OCI
Originally Posted By: GSCJR
2003 Toyota Celica GT-S 1.8L 2ZZ-GE
Out: STS 10w-30/VSP 5w-20 blend and ProSelect filter
In: Fram Full Synthetic 5w-20 and ProSelect filter
How is the 2zz on 20 weight? It was never spec'd below 30 and Lotus recommends 40.
No consumption between changes AFAIK. Driver is not aggressive and changes oil every 5000 kms. or less. I know, I know, waste. It's not my car.
2005 ford explorer 4.0 sohc V6
out: maxlife 10w30 w/pureone
in: castrol gtx 5w30 w/fram tg
2012 scion xb
out: pyb 5w20 w/ purolator classic
in: pyb 10w30 w/ FRAM tg
I will add that I've never seen oil come out of my wife's explorer as dark as the maxlife did. Don't know if that's an indication of it cleaning better than other oils I've run in it, or just the nature of the oil
2000 Dodge Neon
Out: Mobil 5000 10w30 at 1,5XX miles with purolator classic, added Maxlife 10-40 .5qt + .5 of 300ml LM MoS2 can 200 miles before draining.
In: Castrol Syntec 10w-30 with same purolator classic filter. Added the rest of LM MoS2 and 8.5 ounces of Maxlife 10w-40.
I,m still in Florida, so while here I took my grandsons 2002 Camry in for an engine and trans oil change. Engine is a 3.0. with 168K.
Out: PP 5-30
In: M1 5-30EP
Filter: Fram XG 3614
2005 Silverado 1500 4X4 crewcab 5.3
Out: Amsoil SS 5w-30 and M1 AFE 0w-30 makeup oil
Amsoil filter/Napa platinum. 14,145 miles on oil
In: 3qts Delo 15w-40, 2qts Amsoil SS 0w-20, and 1qt M1 AFE 0w-30.
Can you tell that I'm cleaning out the cabinet. Also have a sample of the prev fill getting tested right now. Will trust the OLM on this run, then back to once a year for a while.
Recent changes:
1965 Mustang 289 2V
Out: Royal Purple 15w40, Motorcraft FL1A
In: Mobil 1 TDT 5w40, Motorcraft FL1A
1966 Ford Ranchero 289
Out: MS5K 10w30 with a quart of gas in it (Holley power valve was bad), fram PH8
In: 5 quart frankenbrew, FL1A
Out: frankenbrew with lots of black sludge particles from the gas breakin down the sludge
In: Lucas convention 10w30, dumped an reused filter (oil was a penny, waiting to ensure sludge cleaned up by gas in oil is gone.)
2008 yukon XL
Out: valvoline synpower 5w30, ac pf48 6k miles
In: Same
2009: F150
Out: Castrol Syntec, motorcraft fl-820s 5k miles
In: 5 qts QSUD 0w20, 2 qts penzoil 5w30 syn blend.
Not a passenger car but today changed the oil in my Husqvarner riding lawn mower mower..
PYB 10w-30, Koehler high capacity oil filter..oil just had 14 hrs or so on it.
