Post your latest oil change
1994 Mitsubishi Mighty Max
180,000 miles
Out: Unknown black sludgy stuff (new to me cheap vehicle)
In: Castrol High Mileage and Fram Ultra (to catch said sludgy stuff)
short OCI's to come...probably with Supertech
2007 Camry 58,160miles
Out Havoline 5w20 after 6 months and 3400 miles
In Quaker State Ultimate Durability 10w30 and a new Purolator filter for 6 months
2002 Subaru WRX Wagon 159505 miles
Out: Pennzoil Platinum 5w30/NAPA Gold Filter (14 months/8631 on oil change) - half way thru the OCI there was a couple quarts of top off as the oil cooler was replaced.
In: 4 quarts of Rotella T6 & .8 quart of Mobil 1 0w-40/Purolator PureOne 14460
2000 Mercury Villager 102228 miles
Out: Mobil Super Synthetic 5w30/ Purolator PureOne 14610 (20 months/5835 miles on this oil change). This vehicle would sit, then be driven for a long-ish distance, then sit again.
In: 2 quarts Mobil 1 0w-40 & 2.2 quarts Mobil 1 0w-20/Purolator PureOne 14610
Out- PYB5w20 factory filter
In- PYB5w20 factory filter
Will have a used oil analysis on this run, my second on PYB5w20, soon.
Out: 5qts of 5w30 chevron conventional oil and quick lube filter. In: 5qts of 10w30 Valvoline Max-Life Synthetic Blend with a Bosch distance Plus filter. (Will be putting 5k miles on oil and then going to straight Valvoline Synthetic for another 5k miles. This will be putting 10k miles on one filter as everyone seems to agree it can handle two OCs. Vehicle in signature.)
in the past two days
2005 2500HD Chevy 6.0
ST 10W30, can of MoS2, Havoline T43 filter
2003 Toyota Sequoia
ST 5W30, Carquest Red filter
2008 Chevy Suburban
ST 5W30, Puro Classic L12222
2004 Ford F350 6.0 Stroker
ST 15W40, Motorcraft FL-2016 filter
2007 Chevy 1500 4.3 V6
Rotella T5 10W30, Napa Gold 1036 filter
Changed the oil on my brother's 02 f150 with the 5.4 a couple weeks ago, used a Nap Proselect oil filter and went with National motor oil 5w20.
it uses a little bit of oil but strangely this time around the consumption is down.
i guess sometimes its good to go with cheaper oil.
2009 Ford Fusion 3.0L V6 with 30,920 miles, last done at 29,450 miles on 4/14/13. (Yes, less than 1500 miles in nearly a year)
Out: 5qts Pennzoil Platinum 0w20 + 1qt Rotella T6 5W40. Fram Ultra XG2
In: 6qts Pennzoil Platinum 5w20. Mobil 1 M1-110
OCI: 1 year.
2002 Ford Crown Victoria PI with 160,900 miles, last done at 157,800 miles on 8/25/13.
Out: Mobil 5000 5W20. Motorcraft FL820S
In: Valvoline Maxlife 5W20. Motorcraft FL820S
OCI: WFL
2002 Chrysler Neon 2.0L
Out: Quaker State Conventional or Castrol GTX 5w-20 and Defense filter 5K F/OCI
In: Castrol GTX 5w30 and ProSelect filter
2000 Ford Explorer, 4.0L OHV V6
Out: Valvoline MaxLife NextGen 5w30 (3816 mi), Motorcraft FL-1A filter (7792 mi)
In: Mobil 1 0W-40, Purolator PureOne PL30001
2000 Miata 139,500 miles.
Out - Mobil 1 High Mileage 5w30, Pure One filter 4500 miles
In - Mobil Super 5000 5w30, Bosch filter
Installed new front crank seal and changed oil.
today
2003 Ford Expedition
ST 10W30 high mileage, puro classic 24651 filter
2009 Pontiac G8
Pennzoil Platinum 10W30, Mobil 1 M1-113 filter
2006 Ford Freestyle
Quaker State Conventional 5w30, Wix 51372 filter
