Post your latest oil change
Car: 2001 Mazda 626 / 2.5 Liter ATX / Approx 149,000 miles
Out: Pennzoil YB 10w30 - Carquest Red oil filter
In: Castrol HM 10w30 - Fram oil filter
OCI: 6,000 miles
2009 Mercury Sable 3.5l , 70,770mi
Out: whatever bulk oil the Honda/Toyota dealer i bought the car from used, and a Carquest Filter (looked like an FL-1A equiv.)
In: Meijer(Warren) Full Syn 5w20, FL400s
OCI: OLM
2006 Hyundai Elantra GLS 2.4L
83,350 miles on engine
7,350 miles on oil/filter
Out:
MS5K 5W-20 SN
WIX 51334
In:
M1 5W-20 SN Synthetic
PL 14459
1996 Jeep Cherokee Sport 4.0L AX-15
Out: M1 HM 5w30, ST Syn 10w30, Peak 10w40, MMO
Filter: Bosch Premium 3402
In: Peak 10w40
Filter: STP S16
Mileage: 25,853
Miles on change: 8,332
Out: Valvoline Synpower 0W-20/FRAM Ultra
In: Valvoline Synpower 0W-20/Motorcraft FL-910S
2014 Jeep Cherokee
3.2L Pentastar V6
800 Miles
OUT: Factory Fill
IN: QSAD 5W20 & MOPAR Filter
Just topped up the oil on a 2007 Holden (chevrolet) spark 1.2.
It had it's last change with Shell 10w30 Dino 3 years and 45,000 kms ago!
I was expecting the worst.
There was jet black oil on the very tip of the dipstick, well below the 'low' marker. I took a light and looked inside the engine and it actually looked pretty good baring being heavily varnished. The oil seems to have held up pretty well and there is zero sludging as far as I can see and feel around the rocker cover.
I topped it up with just over a litre of the remaining shell and that only took it to half way to the max level!
Will give it a proper flush and a change tomorrow, but the thing has been lucky!
2005 Honda Accord 2.4l at 164,000 miles
Out: M1 0W-20 with 6,000 miles
In: TGMO 0W-20
Wix Filter
First non-M1 AFE since factory fill
2007 Toyota Sienna 3.5l at 94,100 miles
Out: Valvoline Maxlife 5w-30
In: Caterham Blend (4qt TGMO 0w20, 2.5qt M1 0w40, 300ml Lubro-Moly MoS2)
Toyota Filter (04152-YZZA1)
2009 Chrysler T&C, 3.8
Out-GM dealership bulk
In- Mobil 1 (2 qts 10w/30, 3 qts 5w/30) and Napa Gold Filter.
I purchased a 5 qt container of Mobil 1 10w/30 cheap, so I mixed it with 5w/30. Next OCI will be 3 qts 10w/30, 2 qts 5w/30. Then, start using up the Pennz Ultra I purchased on clearance.
1994 Jeep Grand Cherokee
134,277 miles on vehicle
Out Valvoline Nextgen 10w40 and Microguard filter after 3200 miles after 9 months
In Valvoline Nextgen 5w30 and Purolator PureOne
Leaks some oil and trans fluid but not enough to worry about and still running good
2014 Wrangler Rubicon JK- 5,000 miles.
Out- Pennzoil Yellow 5W-20 Mopar filter.
In- Mobil 1 0W20 Mopar filter.
2002 Nissan xterra 86k
Pennzoil HM 5W30, fram XG 7317
2012 Nissan Rogue
Pennzoil HM 5W30, 10 oz can of Mos2, fram XG 6607
Rogue has 47k, the lady who owns it bought it with 26k and has only done 2 oil changes at the local pennzoil quick lube in that time. going to run some 2k ocis for the next 3 oil changes to try and clean it out
2009 Hyundai Elantra Touring Sport
Out: PP 5W-20, NapaGold 1334
In: Dealer bulk 5W-20, OEM filter
When it warms up in May I'll switch back to PP and a NapaGold or Purolator PureOne.
