Post your latest oil change
1995 SVT Cobra / 4,900 mile OCI
Out: Castrol Edge 0w40 / Motorcraft FL1A
In: Mobil 1 FS 0w40 / Purolator One PL14670
2017 Accord 2.4L 6MT - 106k on vehicle, about 5400 on the oil.
Out -M1 0W-40 with 1 qt HPL PCMO 5W-30 XG7317. I had to add 1 qt of makeup oil (.5 two times) and it was time to add another .5 qt to keep it full. I decided just change it. So officially would have been 1.5qt makeup oil in 5400 miles. PCV only has like 50k on it, maybe I'll change again. Maybe it just is what it is with driving style. I know I have added just over quart between changes since I got it. It also doesn't easy driving on the RPM's being stick shift. ;) :unsure: 😁
In - 1qt HPL PCMO 5W-30, 3qts Shell RGT 5W-30, .5qt Havoline 5W-30 and new XG7317. Using up the random qty's of stuff I have in boxes etc.
2004 Ford Taurus in signature.. (203K)
Out -- Amazon Basics HM Syn Blend 5W30 & Fram XG3600 (1138 miles on oil & 3 oil changes for the Fram)
In --- 4 quarts of Chevron Supreme Synthetic Blend 5W30 & 1 quart of Rotella T6 5W30 Multi Vehicle & Purolator Tech TL20195
What date did you purchase the ROTELLA Multi-Vehicle 5w-30 ? There was a rebate from 2/15/24 > 5/15/24 of what looks to be a $15 gift card at the SHELL site when purchasing a gallon bottle .
2015 escape 1.6 Ecoboost.
Out. 5w20 magnatec and fl910s.
In. Fresh magnatec 5w20 and new fl910s
2015 f150 5.0
Out. 5 quarts Napa 5w20 synthetic and 3 qts of the blend and fl500s filter.
In. Valvoline 5w20 white bottle 6 qts then rislone and Napa synblend to fill the rest. Pureone filter installed
1998 f250 LD 5.4. fl820s removed and out with the shell 5w30 synthetic.
Installed another 820s and put in havoline 5w30 and some rislone
My autocross car, 96 Tercel with a hybrid 5e (1st gen bottom end, 2nd gen head) with a turbo first event of the season is next Saturday so today...
OUT- 3.75quarts of Total Quartz 5w30 and a Full filter with 975miles (winter and really the bulk of that was the last few months breaking in a new Kevlar clutch)
IN- 3.75 quarts of Redline 5w40 and a ChampXL ph2840xl filter.
I also confirmed I can run the larger Highlander filter on it but the block would need to be cleaned off. I have 3 more normal sized folders and really this car doesnt need a larger filter.
