post your latest differential fluid change
2009 Ford F-150 Lariat 4.6L | 6R80 | 8.8" Ford Axle
OCI = 70,000 miles (10 Years)
Capacity: 2.6QTs
Out:
Ford Synthetic 75W-140 GL-5 Gear Oil
In:
Valvoline SynPower 75W-140 GL-5 Gear Oil
Volvo 240 sedan, Dana 1031
Out: Castrol Axle 80W90 GL-5
In: same
OCI: 20,000 miles (per manual)
11 Silverado front and back diffs
Out: unknown
In: Mystik 80w90 front and Mystik 75w90 in rear
12 Suburban
Out: Unknown
In: Mystik 80w90 front and Valvoline 75w90 rear
'05 Envoy rear differential (RWD)
Out: ACDelco 75W-90 GL-5 (88900401)
In: ACDelco 75W-90 GL-5 (88900401)
OCI: 25,000 miles
OCI: 25,000 miles
Grape scented?
OCI: 25,000 miles
Grape scented?
Yes. Pretty expensive around here at ~$32 a quart.
05 Chevrolet Trailblazer: 63,354 miles
Rear diff:
Out: factory fill GM grape juice
In: Starfire Full Synthetic 75w90
Front Diff:
Out: Factory fill GM grape juice
In: Supertech Full Synthetic 75w90
I stripped/rounded off the front diff fill plug. I had to weld a socket to it and take it out with an impact after I heated it. This is why you always pull the fill plug first. If I hadn't been able to remove the fill plug, at least I hadn't drained it yet. Old oil is better than no oil.
2008 Tundra 5.7 4x2.138k, rear diff never serviced
Out: factory fill
In: 3 qts Supertech Syn 75w90, the rest almost a full qt of Mobil 1 75w90
The 2006 Trailblazer in my signature. 250,000km on the clock. 120,000km and close to 8 years on the amsoil 75w90 rear diff gear oil.
In went Federated Co-op group 4 based 75w90.
Will check the front diff level soon but it went be changed unless I find some sort of contamination.
2003 Mercury G.M. W/ 40K miles. I used a suction gun to remove around 2.5 quarts of gear oil from the differential. Probably wasn't needing doing but I got tired of looking at 3 unopened bottles of Mobil 1 synthetic 75w-90 which have been sitting in my garage for fifteen years. Bought them cheap when KMarts started disapearing. I will save the old oil to use in the leaky gear box of my rototiller.
Perhaps the best reason for a diff service I have ever heard.
The Redline 75w85 in my garage is calling me to service the GS...
2017 Chevrolet 3500HD DRW
21,553 miles
Out: FF grape scented 75w90
In: 50/50 mix of Starfire 75w90 and 75w140 full synthetic
The front diff took just shy of 2 quarts and the rear took about 3.5 quarts to get it ~17mm from the bottom of the fill hole. The rear diff was under filled, a little less than 3 quarts drained out. If you fill to the bottom of the fill hole, these 11.5 AAM rear ends will hold about 4 quarts. The proper level per GM is 17-21mm below the fill hole.
2011 Toyota Tundra 5.7L rear differential change
Out: Factory Fill
In: Almost 4 quarts of Valvoline Synpower 75W-90.
1998 Mustang GT, 125k miles
Out: unknown 2 quarts dark swill
In: 2 qts 75w90 Ultralub Full Synthetic & 4 oz of Lubeguard friction modifier mixed in
