post your latest differential fluid change
2011 GMC Canyon 4x4, 82k miles
Front diff: out FF, in ST 80w90
Rear diff: out FF, in Delo syn 75w90
T-case: out FF, in Pennzoil synchromesh
Ram 3500 Ctd 2016 28500 miles, Towed 10,000 lb, TT 4700 miles
Rear Out OEM probably Valvoline Syntec 75W90
In 4.2 quarts, Valvoline Syntec 75W90
Front out, Probably Valvoline 75W90
In 2.5 Quarts Valvoline Syntec 75W90
Tom
2016 Ram 3500 6.7CTD single rear wheel, 3.43 rears
2015 Open Range TT 291RLS, 33.6 ft long, 7700lb empty weight, 9900lbs loaded.
1993 240 sedan:
Out: Shell Spirax HD 80W-90
In: same
20,000 mile OCI per Volvo manual
2005 Toyota Avanza( Kijang) 1.3L rear axle ODO 162,000 miles 269,000 km :
Out:Shell GL5 SAE 90 - with goldenish green hue colour,
In :Petronas GL5 SAE 90.
OCI - 30,000 miles. (Manual , 24,000 miles with SAE 80W90)
2008 Subaru Legacy GT Turbo 5MT trans/transaxle combo-
OUT: Valvoline 80W90 Conventional
IN: REDLINE 80W90NS with 1 qt of Heavy ShockProof
Shifts like Butter and minor gear "whine" is about gone within 200 miles.
my 2011 nissan frontier 4.0 SV 4WD 6 spd manual diffs will be getting Redline 75-90 front + REAR this thursday!!! option out of the cheap overweight 75-140 OE lube in the rear!!
2016 F150 XLT 4x4 2.7L Ecoboost @ 26K
Front diff: Out milky-looking factory fill; In ST 75W-90 ~1.5 qt
Rear diff: Out factory fill; In Motorcraft 75W-85 ~2.5 qt
Transfer case: Out factory fill; In Motorcraft XL-12 TC fluid ~1.5 qt
1988 E-150 gear oil in service 25 years, and 62,690 miles. All my notes said was "synthetic 90w".
The stuff was red like ATF, nice and clean, and probably could have gone another 25 years. lol
This time I gave Valvoline 75W140 and some Ford LS additive a try.
Sorry about the angle of the pic, it's OK on my PC.
98 BMW 318Ti with late 80s 4.10LSD
Valvoline 75W90 FS, had some noise, drained after 30 miles and replaced Redline 75W90. No noise. I could have probably just added FM to the Valvoline.
98 Ford Explorer, 4.0L SOHC Cologne V6, factory 3.73 LSD, 125K
Out - OEM or unknown fill from the truck's past life in SoCal(it was in my adopted "family", it saw service by Mr. Lube in Orange County and probably was filled with Valvoline or Pennzoil). It was a quart low and muddy.
In - 3 quarts of "synthetic" 75W-140LS: 2 of them was Valvoline, 1 was ST. It was still low, so I topped off with 12oz of 80W-90 SuperTech conventional stuff.
2015 Odyssey Touring 60K miles
Out - factory fill, 4 quarts
In - 3.6 quarts DW-1
I always drain 3 quarts outta Hondas / Acuras.
Was surprised to drain 4 quarts.
Will do it 1 more time in maybe a week.
2014 Jeep Grand Cherokee Limited 4x4 - 58K KMs/36K miles
Front and rear aluminum differentials
Out - Factory fill
In - Castrol Syntec 75W-90 Gear Oil
The fluid in the front diff still had a golden color to it, while the rear diff was dark/grey-ish.
