post your latest differential fluid change
Rage...you go back with synthetic in rear diff?
Originally Posted By: RageOfFury
2014 Jeep Grand Cherokee Limited 4x4 - 58K KMs/36K miles
Front and rear aluminum differentials
Out - Factory fill
In - Castrol Syntec 75W-90 Gear Oil
The fluid in the front diff still had a golden color to it, while the rear diff was dark/grey-ish.
Out - Factory fill
Yes! Castrol Syntec 75W-90 that I used is fully synthetic.
I had to replace a leaking axle seal on my mom's 1994 Ford Explorer, so I was forced to change the rear diff oil. Truck has 219k miles on it. I last changed the diff oil about 75k miles ago.
Out: mix of Napa brand conventional 80w-90 and Valvoline Synpower 75w-90 (I didn't buy enough oil, so I used some leftover Synpower to top it off last time)
In: More Napa brand conventional 80w-90 (I bought enough this time).
1993 Volvo 240 wagon
Out: Shell Spirax HD 80W90
In: Castrol Axle 80W90
20,000 mile OCI per manual
2017 2.3 EB Explorer ~22,500 mi
Rear Diff -Out FF 80W-90, In AMSOIL Severe Gear 75W-90
PTU- Out Motorcraft 75W-140 (installed at 9,000 miles), In AMSOIL Severe Gear 75W-140.
Whimsey
2013 Toyota RAV4 XLE AWD 2.5L @ 60K mi.
About 1.5 Quarts Out - Factory Fill
About 1.5 Quarts In - Red Line 75W85 GL-5
Front Diff + Xfer Case / Rear Diff. (Fluid was fairly clear, smelly as usual. Magnets on both had a decent amount of goop/shavings. Anti-seized the hex bolts.)
2000 BMW X5
out probably factory fills
in Castrol Syntrax LL 75W90 for front and rear diffs and Castrol Transmax Dex III for transfer case
Hi Sam Julier,
I own the same year Volvo wagon. I believe the manual states diff fluid at 500-1000 miles then there is no interval after that. 20,000 mile OCI refers to the ATF. Nevertheless, diff fluid is inexpensive and easy to change.
1995 318ti Club Sport 146k miles 15k OCI(due to replacement of pinion seal)
Out: 1.2 quarts BMW SAF-XJ 75W-140
In ; 1.2 quarts BMW SAF-XJ 75W-140
2017 Tahoe 4WD … Changed FF in both differentials and transfer case at one year old / 17k miles
The rear fluid and transfer case looked pretty good with both magnets fairly well loaded … the front end magnet could not hold another spec and that's where the silver fluid below came from:
On my 1993 GMC K1500 rez truck. Out was unknown. The RTV on the pan looked factory but at over 373,000km, the gear oil was not as black as I anticipated. It is an open diff so no clutch packs. It has a mild leaking pinion seal.
In: Co-op Sonic gear oil SL, 80w140. I have about 10 litres left in the pail after using it on my 1500 twice and once on the 3500. I also used up 1/3 quart of Amsoil 75w90 that was sitting around since the fall of 2013. The RTV came out nicely and I used a Fel-Pro blue paper gasket.
06 Infiniti FX45 Front ant Rear diffs. 180K on car, 60K on gear oil. Rear came out looking almost new, front was dark - I suspect due to the heat of being mechanically attached to the engine. Also center transfer case, came out smelling as bad as it did going in.
M1 gear oil front and rear, M1 ATF in the transfer case.
1993 Volvo 240 sedan, Dana 1031
Out: Castrol Axle 80W-90 GL-5
In: Castrol Axle 80W-90 GL-5
OCI: 20,000 miles per Volvo maintenance schedule. Gold magnetic plug very clean.
Sam
2016 Colorado
Out, Factory fill 75W90 front and rear (they looked like different oils)
In Redline 75W90
Tranny case
Out Factory fill (it was overfilled, so they must be pre-filled before installation) - looked like "Deadpool" energy drink
In Redline D6.
Re Deadpool energy drink
[video:youtube]https://youtu.be/Z3eJMjZgyDA?t=180[/video]
