post your latest differential fluid change
2001 Audi S4.
90,000 Miles.
Front, Center and Rear Diffs.
Out: OEM
In: Manual Transmission & Transaxle Gear Lube 75W-90
2004 Audi A4
160,000
Rear Diff
Out: Redline MT-90
In: Amsoil Severe Gear 75w90
The Redline was in the trans and the diff. Had it in there from 125k - 160k. Sucked in the trans. Replaced trans with OEM.
2002 Chevy Silverado 10bolt
Out: Eneos 75W90 puked out the pinion when changing leaking pinion seal.
In: Eneos 75W90.
2000 Mustang V6, 7.5" open diff. 71K miles. Out factory fill? In 3.1 pints 75W90 Valvoline synthetic. Used a lube pump to pump the old lube out the fill hole, measured to see if I got all of it out.
2013 Tundra 4WD with 7,700 miles
Out: Factory fill
In: Amsoil Severe Gear 75w-90
Rear diff took 3.8 quarts, front diff took 1.8 quarts.
Nice thing about Toyotas is that all the diffs have drain plugs.
Used a MityVac 7201 to pump it in.
Super easy job.
1994 Olds Cutlass Ciera, 97,500 miles.
Out: 50% factory fill, 50% whatever the dealership put in in a 2006 drain/fill/filter service.
In: about 7 quarts MaxLife Dex/Merc and Wix filter.
Not convinced the filter has a good seat, but I think the pan holds it in in addition to the seat around the filter neck. Definitly was a layer of fine particulate in the pan and on the magnet.
2004 Lincoln Town Car. 87,100 miles. 3 qts. Lucas synthetic
75-140 gear oil.
2007 Pontiac Torrent
99500 out with factory fill. The gear lube did not look good. In with supertech 75-90 to flush everything out after a week of driving. In with Mobil Delvac 75-90 at 100000 and counting.
2011 Toyota Sienna XLE AWD. 38k mi. Rear diff and Transfer case, out with factory fill. Still looked fine - overly cautious. Red Line 75w-85 as it was the only aftermarket fill that matched the viscosity specs of Toyota. ~0.5 qt in rear diff and 0.85 qt in Xfer.
2005 Chevy Silverado 2500HD Crew Cab 6.0 2WD with G80 locker diff -
Mileage - 126,020
Out : Factory fill ??
In : Amsoil Severe Gear 75W90 (2.5qts)- did not chatter after test drive ,so no Slip Lock added.
2010 Hyundai Genesis Coupe 2L turbo with LSD
Out factory fill (Shell Spirlax ? 75w90) ~1325 mL.
In Redline 75w90 ~1325 mL.
56035 miles
2002 Silverado
Front Diff: Out... Durablend 80W90
In... Same
Drain plug was the usual nasty looking thing... kinda surprising because
this fill was less than 2 years old.
JP
2000 Ford Explorer 4WD with 3.73:1 Traction-Lok (at over 191K miles)
Front
Out: Lucas synthetic 75W-90
In: 1 qt Mobil 1 75W-90 + 0.5 qt Mobil 1 75W-140
Rear
Out: Lucas synthetic 75W-140
In: Mobil 1 75W-140 + 4 oz Red Line friction modifier/break-in additive
Also replaced rear cover gasket
Pretty short OCI (about 1 year)
01 300M 120k miles
originally added Royal Purple 75w90 Max gear, unfortunately I had a little bit of a whine. I drained and refilled with Oreilly's Master Pro GL-5 80w90 and has been perfect ever since... Now I have about a quart of Royal Purple Max Gear sitting around begging to be used, maybe next time...
