post your latest differential fluid change
04 Chevy Silverado in sig
Miles: 178k and some change
Out: unknown brand / miles
In: 2qts supertech 75w90 syn blend and top off with old open bottle leftover Mobil 1 75w90 my dad had sitting in his garage.
2015 Silverado 2500HD. Out with factory fill at 2400 miles and in with Amsoil 75w90 Severe Gear. As was usual for any GM pickup I have had, the rear diff was over 2 pints low from the factory, the front diff was just below minimum level. The front diff and the transfer case, the magnetic plugs were already growing "hair" from the break in wear metals.
1999 Silverado 2WD rear diff with 80K miles
Out: Who knows (likely the factory fill from 1999). The oil was very dirty, low and the pumpkin magnet had no real estate to take on any additional metals. It was way over due.
In: Pennzoil 75W90 and freshly made RTV gasket.
1994 Ford Ranger
Dana 35 front...
Out: nasty unknown fluid
In: Valvoline 80W90 conventional
Ford 8.8 rear...
2015 Jeep Wrangler Unlimited Rubicon
Drained out the OEM 80W-90 in the rear differential and replaced it with M1 75W-140. It is a requirement to go to a 75W-140 when towing. Only 2561 miles on the OEM fluid.
While I was at it I changed the front differential over to Amsoil SVG 75-90.
2008 BMW 528i - 195k
Out: Factory Fill
In: Amsoil Severe Gear 75w90 and a new drain/fill plug.
i sucked out the old fluid since the unit did not have a drain plug. I was able to add just over 1 part of new fluid.
2006 Mazda MX-5 w/ 107xxx miles
Out: factory fill?
In: Super Tech 75W-90 (it was the only brand WM carried)
Might do a few drain and fills and put something full syn in.
2009 Nissan Rogue AWD SL
Out Durablend 80w-90
Same with transfer case
Originally Posted By: howie2092
'06 Durango Rear Diff: (108k miles)
plan to replace open diff with Spartan locker.
Not sure if I should use 75W90 or 80W140.
Truck is AWD and never used for towing. leaning toward 75W90 ST like the front.
Installed locker and new diff fluid today. Cleaned magnet (metal grains and shavings present). Installed Spartan locker. Permatex black on diff cover.
Out: 2Q Mobil 1 75w140 + 1/2Q metal shavings and black goo.
IN: 2Q SuperTech 75w90 Semi-Syn + 1/2Q Mobil 1 75w90.
In the front Dana 60 of my 1996 F350
Out - whatever was in it and the leaky chrome cover
In - Valvoline Dura Blend 80W90 and new Yukon steel cover
2003 GMC Sierra 4x4 w/200,000 miles that I bought new:
Front Diff OUT: Amsoil Severe Gear 75w-90
Front Diff IN: Amsoil Severe Gear 75w-90
This is the 3rd change of Amsoil from the Factory Fill.
96 Toyota Tacoma 75w-140 M1
2002 Ford 7.3 Superduty 75W-140 M1
2015 Ford 150 75W-140 M1
2014 Jeep Wrangler JK Sport
Front Diff
Out - Factory Fill
In - 1 Qt Amsoil SVG 75W90
Rear Diff
Out - Factory Fill
In - 2 Qt Amsoil SVG 75W90
Pre 2002 3rd gen 4Runner differentials seems to recommend thicker oil at mineral 80W90/ 90.
But post 2003 4th gen 4Runner switch to thinner 75W85 ....... does it cause hum/whining noise in rear diff after 8 or 10 year usage ?
Just curious ...
