Does anyone have info to what Porsche's testing involves for the C20 and C30 approval? Are the bench tests the same as for A40?
No. A40 has Nordschlife simulation test.Does anyone have info to what Porsche’s testing involves for the C20 and C30 approval? Are the bench tests the same as for A40?
Are 508/509 subject to VW's Baumusterprüfung? (~650hrs). I would've thought Porsche would've had their own bench test--what sets apart C20 and C30?No. A40 has Nordschlife simulation test.
C20 and C30 go hand in hand with VW508.00/509.00 and VW504.00/507.00.
I think it is (I think!).Are 508/509 subject to VW's Baumusterprüfung? (~650hrs). I would've thought Porsche would've had their own bench test--what sets apart C20 and C30?
I mean, what sets it apart from ACEA 'parent' specs C5/C6 and C3?What sets apart C20 and C30? One is 0W20, another 0/5W30, min HTHS 3.5cp.
Same, HTHS=fuel efficiency requirements. ACEA C5/6 has higher LSPI demands. But don't forget, ACEA is just a start.I mean, what sets it apart from ACEA 'parent' specs C5/C6 and C3?
https://www.acea.auto/files/2023_ACEA_oil_sequences_light-duty_engines.pdfI mean, what sets it apart from ACEA 'parent' specs C5/C6 and C3?
If that graph is correct, how Mobil 1 ESP 0W-20 covers both VW 508.00 / 509.00 and Porsche C20, and also MB 229.71?
why wouldn't it?If that graph is correct, how Mobil 1 ESP 0W-20 covers both VW 508.00 / 509.00 and Porsche C20, and also MB 229.71?
https://www.mobil.com/en/lubricants/for-personal-vehicles/our-products/products/mobil-1-esp-x2-0w-20
Doesn’t VW 502/505 also show up on the bottle when A40 does also?C40 (plus GT) and A40 are the “real” Porsche engine oil specifications. The others are VW clones as far as I can tell.
For that matter, most C40 oils are also VW 511.Doesn’t VW 502/505 also show up on the bottle when A40 does also?
