2008
Then you need part number CB0220. Ordering it from Amazon is safe in this case because it's being sold and shipped directly by CTR.
2008
I thought the relief was on the opposite end of the ball joint ?Push up on the boot, if it does not move then grease came out of the boots grease relief which is normal. that area is where the relief is.
Do not blow the boot up like an elephants truck, a few pumps is all that is needed.
Edit: I just saw you picture, wipe it off and pull the zerk to relieve some grease then put it back, that is way over greased.
thats out of stock dudeThen you need part number CB0220. Ordering it from Amazon is safe in this case because it's being sold and shipped directly by CTR.
Okay, I have seen it on both ends, I thought it had a little relief flap on the bottom. In any case you may have put enough pressure on it pumping that much grease in there it just came out around it unless you ruptured or dislodged the boot.I thought the relief was on the opposite end of the ball joint ?
thats where moog said the relief was
ok so you don't think ill will have to replace the ball joint none of the rubber is ruptured it just came out around the seam, I pulled that grease zerk right after i took the pictureOkay, I have seen it on both ends, I thought it had a little relief flap on the bottom. In any case you may have put enough pressure on it pumping that much grease in there it just came out around it unless you ruptured or dislodged the boot.
If it didn't rupture then you are good to go. There is no engineered seal at the end of the boot like there is with a wheel bearing. The boot just keeps the grease in and the dirt out.ok so you don't think ill will have to replace the ball joint none of the rubber is ruptured it just came out around the seam, I pulled that grease zerk right after i took the picture
ok cool thank you, I was worried I broke the seal or something and I didn't want to have to take everything apart again in like 3 months if it failed.If it didn't rupture then you are good to go. There is no engineered seal at the end of the boot like there is with a wheel bearing. The boot just keeps the grease in and the dirt out.
Moog tells you to pretty much overgrease it because they have their patented relief valve that didn't workPush up on the boot, if it does not move then grease came out of the boots grease relief which is normal. that area is where the relief is.
THIS!I think OP has learned now but I just grease until I see any movement of the boot, then stop. Even that may be too much but I haven't had any problems.
Shows in stock for me too!It's listed as in-stock on my end, and I even refreshed it a few times. Price is $22.83 and free shipping.
I am not from the usa its not in stock in canadaShows in stock for me too!
Disagree. Besides the brief, initial, break in period when they are a little stiffer, greaseable high quality ball joints are superior if only you DO, grease them.Welcome to BITOG
Those greaseable ball joints are a gimmick, outdated, and stupid.
Instead, consider CTR ball joints. They could've even been Kia's OE supplier.
To be sealed, a BJ usually uses a plastic bushing which deforms with road impacts. Potholes can ruin them much faster.
Sealed, plastic bushing BJs are just part of the disposable society mentality that thinks "I don't want to bother maintaining anything, just throw it away when it fails"... which in this case just means it lasts beyond the warranty period.
Granted, plastic tech is fairly mature and good lifespan can be had from these structurally weaker lubed-for-life BJs, but they are always a downgrade from hardened metal on metal, HQ, lubed as needed, BJs.
Kia's OE supplier isn't saying much. Kias are designed to self destruct around 150K mi. if not sooner. There will of course be people who get more mileage than that, but consider the topic, it needs new BJs which many *cars* don't need in their lifetime.
It does not take a rocket surgeon to recognize that metal on metal is better than plastic on metal for shock and wear, if only kept lubricated.
Why?Usually need to replace the ball joint.
I may or may not have done this before.....with a pneumatic grease gun.![]()
these are suppose to have a vent but it obviously doesn't work in my application anyway. the pic below is the moog relief that doesn't work for me anywayWhy?
Fit ball joints on Mercedes knuckles, folks often remove the boot to use press tools. I’ve also seen MB sell replacement boot kits. Granted that’s a different brand and perhaps design.
OP, is the boot split, or did it just bleed out of the top/bottom? If the boot didn’t split I’d think you’re ok.
Aren’t great able joints supposed to self-flush in some designs?
