Ball Joints - school me / help choose.
Lowcountry South Carolina
Well my beloved Xterra - which resides away from home these days, has upper ball joints leaking grease. Both sides. I guess too many pot holes. Nissan doesn't sell just the joint - they sell the entire control arm only. I will likely go that route at some point once I get this car back, but in the meantime I only have short windows to work on it so taking the path of least resistance. It needs to last one semester. No salt here, so I am hopeful the joints will come out easily. I have a proper press.
So here are my options.
Watched a mevotech video talking about Sinter metal joints rather than neoprene. There greasable, which I am OK with. I installed greasable u-joints years ago. Should I go with those? Or the cheap TRW. In the old days would probably have chosen Moog but those seem to be out of vogue?
TRW is now part of ZF. I am not sure whether price resembles quality, but on the BMW M3, TRW is a supplier of control arms and I have TRW M3 wishbones on my 328 in the back. Though, they re far more expensive than that.
So, my gut feeling would be TRW. Maybe @Trav has opinion?
Can you link the Mevotech video? I'm confused as to why they would compare the sintered metal ball to a neoprene boot. Contrary to some opinions on BITOG, I have used the Moog ball joints on several Honda vehicles with very satisfactory results. Those Moog joints were made in Japan or the U.S.
However, for your 2008 XTERRA, I highly suggest the SANKEI 555 ball joints from PartsGeek.
SANKEI 555 Upper Ball Joint
In any event, don't buy the low quality Mevotech ball joints w/blue boots or poor Suspensia parts.
All those are pretty lousy unfortunately. Can you get the Sankei 555? Those or OEM are all I use on Japanese cars
This. I despise greaseable ball joints and consider them to be a solution to a problem that never existed on light-duty applications.
555 is aftermarket but ok. They have a part # for this application -- SB4981. About $36/ea.
I have 35,000 miles on Mevotech Supreme upper control arms on a Silverado. No issues. It has a pinhole leak on one boot but the truck is on gravel roads a lot. Greasable ball joints. My greasable GM ball joints on my Burb have 265,000 miles on them.
What year is your Xterra? How do you like it?
A 2010-2015 seems like a decent replacement to my Blazer. Similar in size and fuel economy. They sell as reasonable prices too.
Best vehicle I have ever owned by a long shot. Now at 410,000 miles.
2005 to 2015 are almost the same, with a few nuances. 2011-2015 are generally considered the best as they have some bugs worked out. Same powertrain as Frontier until 2019 so parts availability is still good. If you want the whole run down by year PM me.
I installed Mevotech Supreme upper and lower control arms on a 2013 Ford C-Max. Still going strong after 130K miles. Outlasted the junk Motorcraft parts which lasted 25K. I’ve also installed their TTX line of parts in my F-150 but only have a few thousand miles on them; they do seem like higher quality.
I found this on an '04 Ranger the other day. The other side was a black boot. I told him I don't know what it is, but it's definitely aftermarket.
So many of these aftermarket booted products might have "ok" internals but apparently producing quality rubber, neoprene or plastic eludes us. It feels like building a decent house then deciding to go cheap with a straw roof.
In this case there was no play and we don't get salted roads. I told him he can certainly wait until it gets sloppy.
