2012 Mazda 3: Ball joints again?
VA
Time to throw more parts at the beater. It got front wheel bearings and ball joints last fall. The ball joints were an add-on because the boots were torn or tore in the process of front-end takedown. (Fun story, it ended not being the bearings. It was cupped tires.)
Now the CV shafts are spitting from the outer boots. My car seems to be an odd single-year combo (2012 skyactiv 2.0 six-speed auto) so no boot kit available and I haven't been able to solve the problem with fresh bands on the outers. So it's going to get shafts.
And there is a horrible popping from the front end, both sides it seems that has developed since the prior work. Mostly when turning the wheel (but not every time) and very rarely over a bump. I can feel lateral movement between the knuckle and lower arm when my wife turns the wheel. The popping developed slowly since doing the prior work but was not initially evident.
Were my new ball joints duds? Sankei 555? Are they likely dead in only 2k miles, or are they popping and moving within the control arms (press in style)? Do ball joints pop or am I going to wind up doing lower control arms and/or strut mounts?
Doing ball joints again is going to be a pain, but I'm there anyway for CV shafts. Doing lower arms is going to be a bigger pain. 95k on vehicle.
Bitog crystal ball experts unite. This car's biggest problem seems to be the person working on it.
Are you sure that it's not the strut bearing plates? Without hearing it, it seems pretty unlikely that the ball joints would 1) fail that soon and 2) make a popping noise.
I 100% haven't ruled strut mounts/bearings out. Strange thing is that it doesn't pop with every stroke of the wheel. It would make sense if they were not happy because I had to be pretty abusive with a hammer to get the knuckles out of the car.
Sachs is another $30 a side and...I'm practically there anyway.
And that I can discern lateral play in at least one of the ball joints.
My son's 2017 has had three ball joint failures in 160k miles, twice on the driver side, once on the passenger. All factory parts from the local dealer, no aftermarket. And now about a week ago he told me he's hearing a knocking sound again while going over rough roads, same sound as the previous two times. Soon to be a fourth replacement? Cant whine too loudly, other than an idler pulley and one wheel bearing its the only thing we've had to repair in almost 10 years and 160,000 miles, but jeepers creepers. What's with the ball joints? I had to replace three on his 2012 Mazda2 before 150k miles as well.
Further investigation via prybar, looks like one of the replacement ball joints is loose in the control arm. The popping is likely the control arm shifting vertically on it depending on load. Looks like I'm in for a full arm replacement or two. The joints were tight going in but this one has surely compromised the stamped bore by now.
Now to debate what else to do while I'm there. Struts ride okay and aren't leaking. Bellows and jounce bumpers look good. Mounts seem okay, so I think just arms and shafts for now.
Rotors are trash and one of the end links has a torn boot but both of those are easy to get at later. I think those will stay for now.
Managed to tear down the front end last night and have it all back together in five hours including all the cv joint grease cleanup, test drive, and family dinner. I managed to get the front control arm bolts out without pulling the lower pan. Now rattle free and quiet, fingers crossed it holds. Control arm removal and replacement wasn't that bad since the shafts were also coming out and the sway bar got detached.
New CV shafts (trakmotive), and delphi lower control arms. "While you're there" items included delphi sway bar links, Delphi sway bar bushings, and some cheap coated rotors (quality-built) since mine were pitted and badly rusted inside the hat. Copper anti-seize, red Loctite, etc. I stripped a stud on one outer tie rod end (used a wrong torque spec?) so it'll get a pair of Delphi outer tie rod ends (it never ends) and a toe-and-go at the upcoming annual inspection. For now it is holding with a jam nut behind it.
Last fall it got four new wheel bearings (Koyo front, Timken rear), an "upgraded" set of rear adjustable camber arms (at the advice of a local alignment shop), and an alignment. So $820 for two rounds of parts cannon (plus lots of hand soap and brake clean) I guess I should give it a good wash and plan on keeping it for awhile.
New Bosch ceramic pads all around, fresh TYC headlight housings, Michelin Defenders...I'm that guy with the "nice" beater. Maybe the transmission deserves another drain and fill in the near future. You touch it you own it, and I've now touched most of the things. It's clean and generally rust free so I guess she stays. I shouldn't complain. In 14 years the only repair the car has needed has been a mass airflow sensor and now some suspension parts.
Cuz that would've been $5K of work...
On a $3k car. Which is why paying a mechanic to swap cheap parts on a cheap car is silly. The most obscure tool I've used was a 30" breaker aside from loan-a-tools from o-reilly (wheel bearing press, slide hammer, ball joint separator.)
Then again, a good mechanic would've correctly diagnosed the cupped tires rather than going after the wheel bearings, which eventually snowballed into the rest of the work.
We have a 2012 Mazda 5 so basically the same car only bigger. Only work that needed done was both rear wheel bearing assembly's. I recently replaced the water pump even though it was fine and the serpentine belt because it has 168k on it now and needed new antifreeze. I have replaced the transmission fluid 3 times now with one filter replacement. We just love how simple it is to keep up with and how precision it drives. We are getting between 28-29 mpg on this wonderful little mini-van. I added a Serius XM adapter to the factory radio. That was a challenge..
This one has really only needed an MAF sensor back in 2020 as far as repairs go. (The sensor was specific to the skyactiv, dealer only at that time. I was able to unplug it and limp the car home but it wouldn't run at all with it plugged in.) Everything else has been maintenance. Two sets of tires, three batteries, some air filters, and one set of brake pads on each axle. Transmission fluid, coolant dumps, and a set of spark plugs at book mileage. Until now.
I mistook cupped tires for wheel bearing noise last fall and that's what kicked this entire episode off. The front ball joint boots were split despite me not using a pickle fork, so I went ahead and replaced those, but apparently the bore in the arms got distorted and they began to move/pop shortly thereafter, thus the new arms this go around. The rotors were rusted onto the hubs so bad that I had to pull the full knuckles from the struts and drive them off. Somehow I think the entire wheel bearing episode stressed the already aged CV boots, making them both begin to leak: oddly from under the outer bands, not apparently from cracked rubber. I tried several times with replacement bands to stop the leaking but could not.
My alignment guy reccomended aftermarket adjustable camber arms for the rear, which would work on your 5 too.
And then the outer tie rod ends were my fault. Those went on today and reset front toe by tape measure.
All in all it's been cheap to maintain. Total receipts to date for all maintenance and repairs since new (and upgrades like dash cam, weathertechs, HID low beams, etc) are less than 5 cents per mile. I really like how the car drives. They did a good job with the steering. If it wasn't for the road noise it would be a really good little car, especially if it had the same engine with a manual.
Much of this could've been avoided if I hadn't taken things apart last fall (correctly diagnosed and replaced tires) but reality is the ball joints, sway bar links, and cv shafts probably would've needed attention anyway down the road.
I just hate replacing so many good factory parts with replacements of questionable origin. I can't sweat it too much. It's not like we will have it another 14 years. Someone could total it for me on the way to work next week.
I know what you mean about your car being destroyed. In the past, each time I would wax and clean up one of our vehicles it would be destroyed in a wreck or something like a hail storm. I finally gave that up and now just have a memebership at the local car wash and can get it washed and hot waxed daily if necessary. We also have a 2014 Mazda CX-5 that is another great little Mazda. It has the 2.0 and my 5 has the 2.5.
