Which brand of control arm/ball joint assembly?
Traveled approximately 700 miles this holiday weekend. In doing so, I developed a metallic clunk on the driver side front. Sounds like a ball-joint or strut mount.
In the event of being a ball-joint, I know my control arms are an integrated unit that is non-serviceable. For the uppers anyway.
What brand is best or would the consensus recommend? Mooog, ACDelco Professional, Dorman? Honda OE?
Should I replace both upper control arms and lower ball joints?
In this order and I'd only replace what needs replacing now as the other could last waaaaay longer. For example, I have replaced the Passenger Lower Control Arm, twice on the '06 Mazda3 in my signature(145K) but the Driver side is still OE and tight!
1)Honda OE
2)MOOG(Problem Solver) - tie
2)ACDelco Pro - tie
Dorman
OE didn't do that well if that's all the mileage you've got. Id look at moog if the quality appears good and price is advantageous.
Originally Posted By: JMJNet
I think it depends on what kind of car are we talking about?
This
But I have used Moog and delco w zero issues
Moog "problem solver". Probably the only one they make, now, but as your car gets older they might come out with a cheapo one as well.
Some of the Moog Problem Solver are Three 555 made in Japan. The upper ball joints I just recently installed on my Toyota pickup were Three 555, and they also had the nipple on them to expel old grease. Three 555 seems to be very good quality.
If lemforder or meyle aren't available then either go OE, or, people speak highly of moot problem solver but I've never used them so can't comment.
Watch out - a lot of Moog's control arms for imports are the R-series "cheap" line. YMMV. I'd go OEM, Beck or Dorman.
