Originally Posted By: ez_livin
I have an 06 Yamaha V Star 1100 (air cooled). I've been using Rotella T 15-40 and it seems to work great. BUT I am thinking about switching to Rotella Synthetic 5 40. does the 5 40 shear faster than the 15-40? Would you change? Thanks for your advice!
This is very good reading.....
CLICK HERE - CALSCI Website
Also, this is off the Shell website.....
Here's the scoop on ROTELLA T use in motorcycles.....
Shell ROTELLA T SAE 15W-40 and ROTELLA T Synthetic SAE 5W-40 are universal oils, meeting needs of many 4-stroke gasoline as well as most diesel engines. They have performance credentials (API Service Categories SL and CI-4 & CI-4 PLUS) for lubricating both kinds of engines. Consequently, ROTELLA T can be a good choice for four-stroke motorcycle/ATV engines.
It's best to consult your owner's manual for recommended oil quality. If your engine manufacturer recommends oil meeting any of these API Service Categories; CF-4, CG-4, CH-4, CI-4 & CI-4 PLUS, and/or SH, SJ, and SL, or any earlier but obsolete category, then ROTELLA T may be a good choice.
ROTELLA T does not contain friction modifiers that are added to many passenger-car-only-oils, and it does not comply with all requirements of ILSAC GF-1, GF-2 and GF-3 (the ILSAC oil specifications are often recommended by many gasoline passenger car engine manufacturers). That can be good for motorcycle/ATV use. Friction modifiers can upset wet clutch operation. And the ILSAC requirements limit phosphorus content. Diesel engines and other engines with highly loaded valve trains, as well as transmissions, need extra (compared to passenger car engines) extreme pressure wear protection, which is provided by an additive that contains phosphorus.
