So I found the source of my sister in laws dripping trans fluid. There was one pin hole leak spraying fluid out. From doing research it appears trailblazers have problems with corroded lines. Her lines are pretty corroded. She doesn't have much money and the vehicle is used only a little.
My solution was to buy some 3/8 inch trans hose . I slit it so I could slip it over the line and then used 3 hose clamps to pull it tight against the pinhole area. That has stopped the leak for now. I know this is only a temp fix as the lines will only get worse.
Anyone have similar issues?
