Thanks for the suggestions. I will research high performance lubricants.
I have been reading your posts on several Ecoboost threads. Do you share the concerns others have about viscosity falling out on the 5w-30s people are using to 5,000+ OCI?
Well, it's kind of funny you ask. I used Ravenol DXG early on in my ownership (what appeared on paper to be a very robust oil on all fronts) for several OCIs, and yes, I saw the viscosity drop out of grade on it. I wasn't super concerned, because all other indicators didn't show there was distress. But, I did want to get something that would stay in grade.
After researching HPL, I found that one of their large fleet customers runs ~12,000 3.5 EcoBoosts on 15k OCIs with 5k filter changes, and has roughly 180 million miles worth of data,
per year, over the past decade or so that HPL's PCEO 5w30 has been used in this fleet. HPL uses (correct me if I'm wrong in my understanding,
@High Performance Lubricants or
@RDY4WAR!) oxidative thickening on purpose to combat some fuel dilution, so it is normal at an early point in an OCI with this oil to see "some" viscosity loss while still maintaining the designated grade, and then as the use continues, the oxidation will thicken the oil up some but it is not detrimental because of the other components in the oil (alkylated napthalenes and esters) are designed to continually clean surfaces and transport any debris to the filter. Also, in the regular PCEO HPL uses a very shear-stable VII so you will not have mechanical shearing concerns, of which the EcoBoost is known for.
So in a "normal" OTS oil in an EcoBoost, you'll see fuel dilution and mechanical VII shearing impact viscosity, and is usually why most owners do very short OCIs. With HPL, you won't have the mechanical shear, and the oil is designed to thicken slightly over time, so you get a double bonus there. The 5k filter change & top-up oil not only removes any cleaned debris, but also gives the oil still in the sump a freshen-up to keep the viscosity in the grade window and give TBN a small boost. Sure, it's more expensive than other oils, but have you priced an EcoBoost timing chain/phaser or entire long block lately? You buy from their retail distribution website,
Advanced Lubrication, and be sure to use code BITOG15 for 15% off your order.
