I see you get a free used tire with the purchase of a used engine. Nice!
Sadly I had to provide the dryrotted tire. They didn't even include that!I see you get a free used tire with the purchase of a used engine. Nice!
New engine is in and it fired up ... albeit poorly ... yesterday. I had the new engine with the spark plugs out and barred it over by hand. Was making some pretty bad timing chain noises from sitting for a few years. So once I got it back in, I cranked on it for a while with no coils or injectors to try to prime up the tensioners. Still have no grounds , alternator, exhaust, belt, coolant etc. Just wanted to make sure it wasn't making too many bad noises once it ran. Only ran for a minute or so to make sure that it wasn't going to knock or jump time or anything crazy. It's running richer than Bill Gates and I ain't kiddin!
Tonight I'm going to hook up the exhaust manifolds (sorry neighbors ...) , throw some distilled water in it and by pass the heater core, put on the belt / accessories and try to run it for more than a few seconds to see if it gets sorted out. There are no grounds so I'm guessing that and lack of alternator were causing it to be a git off.
I can honestly say the single hardest thing (and what took me longer than everything else) was getting the @#$@#$ing starter out. Literally took 6 hours to get the starter out. Nuts!
The good thing is, when I was cranking on it to try to pump up the tensioners, it sounds normal. Doesn't have one cylinder where the starter speeds up due to no compression.
With the old engine out I removed the spark plugs and barred it over by hand. I can have my finger in the #5 cylinder and and it'll go right past the compression stroke without pushing my finger out.
I watched a few ScrewTube videos of the starter removal with the engine in the chassis. If I'm looking at the same engine, holy smokes. One guy used like a 18" train of extensions, wobblers and universals to get to that top bolt. Another guy used a universal, short extension and a deep socket and got lucky, blindly stabbing at it over the solenoid.
At least you can see the starter. I hope I never have to deal with the starter on the Lexus. I can't even see it without removing the intake manifold. It's bolted to the engine block in the valley between the cylinder banks. I'd seen it last fall when I had the manifold off. I contemplated just replacing it but I thought, "If it ain't broke, don't fix it".
I just jinxed myself.![]()
one of the easiest jobs out therePanther starters really are the worst! there's absolutely no reason for that 3rd bolt, two bolts of a slightly larger diameter would have easily sufficed. I believe the OE bolts are M8x1.25, so two M10x1.25 and maybe an alignment dowel would easily have solved any reliability issues.
Who/ what is the mobile bolt removal guy? I would love to find a guy like that.I ordered a Dorman exhaust manifold and sent it back immediately. Horrible. Noticeably smaller ports and looked like a crack from the factory. Got the Ford part for not much more. 1 stud was broken and not easy to access, I called the mobile bolt removal guy. I didn’t want to make it any worse. Used the Dorman hardware.
Such a nice looking mercury. There’s a reason they have a cult following. Glad the intake gasket was easily found and fixed.
Check online or maybe check with the Ford dealer. He said they are his biggest customers.Who/ what is the mobile bolt removal guy? I would love to find a guy like that.
I got VERY lucky when it came to getting the exhaust manifold bolts out of the "new" engine. They came right out with a 3/8 ratchet! That never happens!Check online or maybe check with the Ford dealer. He said they are his biggest customers.
He comes to your house/shop and removes the broken bolt. If it’s completely inaccessible or the part is already off he even has his own shop with the extreme voltage machine that zaps the bolt out of existence and leaves the threads in tact.
Not cheap but worth it.
It does whistle at high load / low RPM. It's the EGR tube. I never tightened it all the way into the manifold. But I really don't feel like taking the exhaust down again to fix it. So it is what it is. As long as it doesn't set an EGR code, I'm leaving it alone.
