- Joined
- Apr 19, 2025
- Messages
- 278
I'm not trying to sell you anything it's your car. I normally don't get too caught up in specs, but this one I've learned from experience to take seriously.
Here's the type of oil-related failure in a pentastar I'm talking about:
Finally found a copy of the MS-6395 spec for those interested.
https://jeepoffroadadventures.com/wp/?page_id=801
Just FYI. If you're not going to listen to reason then maybe someone else who sees this thread will.
This is my 20 Promaster 2500 with 85k. I bought it used in 21 with 30k (Amazon lease).
This is my work vehicle, I've run PP5w-30, and M1 euro 0w-40. All oils changed between 5k and 6k.
Oil filter housing oil leak so I tore into it. There is a lot of stuff in the way where they shoe-horned this pentastar where a Fiat 4cylTD was supposed to go.
Had to replace leaking radiator which made access much better for this application.
Found weeping valve cover Gaskets so decided to change those while I was there. Low and behold I see this. Some other cam lobes and rollers look similar. Not...
- Fabulous50s
- Forum: Mechanical/Maintenance Forum
