Awful Start Up Tapping After Sitting Several Weeks (Video Link Inside)
North Dakota
For various life reasons, I hadn't started my 2012 Jeep Wrangler Unlimited for a few weeks. I put it on a battery tender during that period, so it cranked fine that day. Since it had been sitting for so long, I gave it a few seconds of cranking in clear flood mode to help get oil back up to the top end. Instead, I was greeted by the most godawful ticking I've ever heard this specific engine produce. I was a in a bit of a panic state, so I can't say for sure how long it was making this noise, but I'd estimate 60-90 seconds, possibly 120. I tried a quick, light blip of the throttle in hopes that it would help oil get where it needed to be.
Because I was panicking and not thinking straight I didn't turn it off and try another clear flood mode crank and instead backed out into the street (didn't want to be late for work). By then, it was no longer audible. There were no other symptoms or residual issues, it ran great, got to work fine and the idle sounded great warm when I arrived. Just to check, I restarted it there briefly and it was quiet. I don't recall seeing the oil light coming on, either time.
For the sake of context, I'd changed out the rocker rollers and lifters a couple years ago with revised parts to get ahead of any Pentastar tick. At the same time, I'd put in a Baxter oil filter adapter that allows the use of spin-on filters with an anti-drainback valve. Ever since then, my start ups have been smooth, largely quiet, and free of the clatter I had with my OEM cartridge filter setup. By all measures, despite the prolonged sitting, some clear flood cranking should have done the trick and prevented at least some of this gut-wrenching racket.
Anyway, I'm absolutely kicking myself for not starting it periodically while I was amidst "life stuff." Parts to replace the rollers and lifters are double what they were when I last did it and 32 of each are required. Pricing on all four camshafts is up too. It'd probably cost me at least $1600ish to do it myself. I'd prefer not to have to re-do the job. Unfortunately, Google searches have yielded nothing similar to my situation and I can't explain the hows and whys in this case. I know sitting isn't the best thing for vehicles, but it seems a bit ridiculous. I feel like I must be misdiagnosing it as valvetrain clatter, but that's what it sounds like.
When I got home, I did change the oil and filter. I didn't see anything unusual in the oil and I cut open and inspected the filter element of the (EcoGard aka O'Reilly's MSL filter) and didn't see anything alarming either. If anything, it looked better than previous cut-open filters. So, I'm a little puzzled right now. I don't want to throw the baby out with the bath water, but it has me concerned.
Pentastar 3.6 Start Up Noise
Cracked exhaust manifold or loose manifold bolts? Perhaps the leak “seals” up after the heat expansion takes place. Just a thought….
Almost sounds like the exhaust manifold. Lifters are loud, but not as loud as the manifold, and usually clear up quicker.
Now that you mention it, it does sound a bit like an exhaust leak.
Normally, the Jeep has never sat more than 7-10 days when I rotate shift weeks in the winter. It was also during the coldest weeks of the winter that it was sitting in the garage for 3-4 weeks. I think the temp in there was high 30s to low 40s. Maybe it's possible that sitting cold that long caused an exhaust leak that went away after warm up. But yeah, I haven't heard anything since then and it's been a week now. Starts and runs smooth as a sewing machine.
I have had a few of my sports cars sit for 3-4 months without being started if we have a terrible winter and they never made any strange noises on the initial startup. I haven’t driven or started my Corvette in two months and it’s likely I won’t be driving it for another month. I plan on videoing that first start just to see if anything happens differently
Right, by all accounts none of this should have happened, it's definitely abnormal. Given all the pieces of information and surrounding factors, I still can't quite determine why this happened and then continue on as if nothing occurred. Piston slap? Exhaust leak? Maybe. I'm not sure.
If it’s quiet now so there’s no easy way to diagnose what the noise was. Not much to do but drive it and continue to maintain it well, as you have in the past.
No idea but if others mentioned it's annexhasut leak can you get a bore scope on there to look for carbon?
If you have a laser thermometer check for each exhaust manifold flange temperature difference?
Smoke test. Add several ounces of transmission fluid in the intake when engine is cold/noisy and watch for smoke in and around exhaust manifold and flanges.
Based on the year, this Jeep should have the 3.6 Pentastar, which does not have exhaust manifolds, they are part of the cylinder head.
Tell us more about this oil filter adapter.
