Ford has speced their F-150 engines for 5W-30 despite the higher CAFE fines Ford might have to pay.View attachment 223467Just another data point. I wasn’t able to find PUP, so I’m running PP 0w20 this time. I asked about how they think they compare, and they said it should work fine. Just FYI, the oil life meter said I needed to change at almost exactly 10k, and I ran 1,300 past that for science because they recommended to try 11-12k last time.
Seems like I’m good to 11k. I’ll stick to no more that and do another UOA in 20-30k miles.
You might want to consider to switch your Dodge RAM to 5W-30 for the higher High Temperature / High Sheer protection.
Just google HTHS wear graph.
If you are into extended oil changes with Pennzoil, Pennzoil very recently changed their formula and marketing to make their oils 15,000 OCI capable. Of course their marketing has a lot of fine print, but the newer formula might be a better fit for your use case.
