Put in Pennzoil platinum 300 miles ago and I'm getting 3-5 mpg better than the previous oil I used (k&n) excited to try ultra platinum next I'm very pleased with the product. 2020 Impreza 5mt 100% short city driving from 22mpg to 25-27mpg.
it was actually hotter with the k&n oil but still got worse mpgAre you in the U.S. and experiencing the )))HEATWAVE((( like the rest of the country is?
All of our vehicles fuel economy is up in this heat.
nope nothing has changed in my driving ill see if it stays consistent but I'm very happyWere you going downhill?
Pennzoil Platinum is the thinnest oil out of the bottle and quickly drops below grade. If you do your calculations honestly over the long term, you are unlikely to see an improvement over 1mpg. Not worth the reduced engine life IMO.Put in Pennzoil platinum 300 miles ago and I'm getting 3-5 mpg better than the previous oil I used (k&n) excited to try ultra platinum next I'm very pleased with the product. 2020 Impreza 5mt 100% short city driving from 22mpg to 25-27mpg.
Something else is going on here. I am not convinced any oil will produce results like that.Put in Pennzoil platinum 300 miles ago and I'm getting 3-5 mpg better than the previous oil I used (k&n) excited to try ultra platinum next I'm very pleased with the product. 2020 Impreza 5mt 100% short city driving from 22mpg to 25-27mpg.
Many things have changed. Not least of which could be the fuel, a study I linked once showed that even at the same gas station and irrespective of summer/winter blends the energy density of gasoline varied about 4%. Without using standardized test fuel no real-world determinations are possible. Measuring a fuel consumption difference between oils requires a laboratory and using a test such as ASTM D8114 which isolates variables so that the small change isn't deep down in the noise.nope nothing has changed in my driving ill see if it stays consistent but I'm very happy
Dont forget nitrogen filled tires…If you put in Penzoil transmission fluid, you should be able to gain another two or three miles a gallon.![]()
I prefer hydrogen…makes the car lighter and good for 5 additional MPG.Dont forget nitrogen filled tires…
With or without magnets?Intake Tornado. Thank me later.
Huh?????Pennzoil Platinum is the thinnest oil out of the bottle and quickly drops below grade. If you do your calculations honestly over the long term, you are unlikely to see an improvement over 1mpg. Not worth the reduced engine life IMO.
