Pennzoil Marine Premium Plus 2-Cycle Synthetic Blend "TC-W3" okay in small air cooled engines?
So I have been feeding a steady diet of 50:1 Pennzoil Marine Premium Plus 2-Cycle Synthetic Blend Oil into my Weed trimmers, chainsaws and backpack blowers for a number of years now without anything bad happening...
However I stumbed across some information that said the TC-W3 2 stroke oil is only for use in water cooled two stroke Marine applications because air cooled two stroke engines run much hotter. This got me thinking.... Have I been doing slow and/or unnoticeable damage to my equipment by running the TC-W3 oil??
Pennzoil also offers a "Pennzoil Premium Outboard and Multipurpose 2-Cycle Oil" that is both TC-W3 and ACI TC rated and when comparing their "flash point" and "viscosity" specs i don't see any significant differences.
I've also found ACI TC rated oil specs from other manufacturers with higher or lower flash points than both Pennzoils I've mentioned above.
Am I looking at the data all wrong? Why shouldn't I keep using the Pennzoil Marine Premium Plus 2-Cycle Synthetic Blend Oil TC-W3 rated oil in my little air cooled engines?
I really want to know how this could make any difference! I've attached spec sheets below....
View attachment 293889View attachment 293890
I heard that Marine 2smoke oil gets fired in air cooled engines.
I've never decided I needed to test that theory as echo redarmor is probably just about the best 2stroke oil for the money, run it at 40:1.
So I took a trip to Walmart and picked up a few bottles of the VP Racing Full Synthetic 2 Stroke oil. I decided to use this going forward for peace of mind.... The other options for oil at this quality level are either more expensive or are unavailable locally. I am not convinced that this decision will make any difference however for the amount of oil I use as a homeowner the cost difference isn't going to kill me.... It is about 4x the cost of what I was using before!
I wish there was some long term testing available to show how the marine 2 cycle oil is insufficient. Throughout my extensive searching I have come across dozens of people who claim to have been using marine 2 cycle oil extensively without issues. Some of these posts have been from landscapers who are going through a lot of oil so the cost savings for them is important. I have not come across one test or person who has claimed that using marine oil has damaged or shortened the life of their air cooled equipment.
I see tons of info about how the air cooled 2 cycle oil is designed for higher flash points due to higher operating temperatures however I have found air cooled rated oil with lower flash points than the marine oil I was using. I've attached an example below. You can compare this to the data in my original post.
I'm citing my first post on this thread:
Basically you can run any 2 stroke oil. High viscosity oils can be used at 40:1 and low viscosity oils can be run at 32:1 or 25:1.
Two-stroke oils just as four-stroke car motor oils differ in three major aspects:
1. Mineral/conventional vs synthetic blend or semi-synthetic vs full synthetic or 100% synthetic
2. Viscosity @100C - 8 cSt (SAE20) vs 14 cSt (SAE40) and anything in between
3. Gas : oil ratio (oil change interval for the four-strokes)
Any combination of the first two aspects defines the third aspect.
The first two Pennzoil oils you asked for are synthetic blend and mineral:
- Pennzoil Marine Premium Plus - synthetic blend
- Pennzoil Outboard & Multipurpose - mineral
The new oil you bought VP Racing is full synthetic.
So that might defines in this case why the oils look similar on paper, even the VP Racing is lower viscosity with lower flash point too, but to have different performance. However on this SDS says that the VP Racing has flash point at 108C (bottom of page 4):
https://vpracingfuel-my.sharepoint.com/personal/compliance_vpracingfuels_com/_layouts/15/onedrive.aspx?ga=1&id=/personal/compliance_vpracingfuels_com/Documents/VP Racing SDS/Small Engine Fuels - Oils/VP SEF Full Synthetic 2-Cycle Oil/United States/VP SEF Full Synthetic 2-Cycle Oil - United States - English.pdf&parent=/personal/compliance_vpracingfuels_com/Documents/VP Racing SDS/Small Engine Fuels - Oils/VP SEF Full Synthetic 2-Cycle Oil/United States
Probably the main difference in this case is that the VP Racing oil is fully synthetic, has higher viscosity index and has ash, which is missing in the marine oils. Also it says that the VP Racing oil is ester fortified. Google search or here on the forums about esters in 2-stroke oils.
It appears that VP Racing has low viscosity and flash point compared to motorcycle racing oils that are also ester fortified and their viscosity starts at at least 11 cSt @100C and their flash point at at least 150C.
A buddy of mine gave me this exact "Pennzoil Marine Premium Plus 2-Cycle Synthetic Blend "TC-W3". I've been using it in my gas can for my leaf blower, string trimmer & chainsaw with very good success for the past two years.
I'd discontinue using the tcw3 marine oil. Many years ago I unknowingly used marine 2 stroke and after a couple of seasons after pulling the spark plug the piston top was fairly carboned up. With my Stihl it's had vp racing synthetic and Stihl 2 stroke oil for 5 seasons and the piston top looks remarkably clean.
My weed trimmer gets used for the duration of about 1.5 - 2 full tanks of fuel at almost wide open throttle when I need to trim a large hill in my backyard that is too steep to mow. My backpack blower is used about the same when the fall hits and the leaves are dropping.
There has been no shortage of long term wide open throttle RPM use on any of my equipment.
That helps alot. 2 stroke equipment that idles alot tends to carbon up the spark arrestor and whatnot.
I just wanted to accent on the fact that large displacement 2-stroke engine (350cc and over) regardless of air or water cooled dissipate heat much better than 30-50cc air cooled lawn equipment engine. And they run at different RPM too.
Also many synthetic oils don't stay in suspension pre-mixed with gasoline below 32F and some even below 60F.
The ticker the oil, the hard stay in suspension at low temp. That's why marine and snowmobile oils are always low viscosity.
Do you have a source about the synthetic oil suspension issue?
