Go to orileys and buy the quart bottle of Lucas 2 cycle oil for $10. It's got the correct ratings for your needs.
I dont support snake oil companies.Go to orileys and buy the quart bottle of Lucas 2 cycle oil for $10. It's got the correct ratings for your needs.
I heard that Marine 2smoke oil gets fired in air cooled engines.So I have been feeding a steady diet of 50:1 Pennzoil Marine Premium Plus 2-Cycle Synthetic Blend Oil into my Weed trimmers, chainsaws and backpack blowers for a number of years now without anything bad happening...
However I stumbed across some information that said the TC-W3 2 stroke oil is only for use in water cooled two stroke Marine applications because air cooled two stroke engines run much hotter. This got me thinking.... Have I been doing slow and/or unnoticeable damage to my equipment by running the TC-W3 oil??
Pennzoil also offers a "Pennzoil Premium Outboard and Multipurpose 2-Cycle Oil" that is both TC-W3 and ACI TC rated and when comparing their "flash point" and "viscosity" specs i don't see any significant differences.
I've also found ACI TC rated oil specs from other manufacturers with higher or lower flash points than both Pennzoils I've mentioned above.
Am I looking at the data all wrong? Why shouldn't I keep using the Pennzoil Marine Premium Plus 2-Cycle Synthetic Blend Oil TC-W3 rated oil in my little air cooled engines?
I really want to know how this could make any difference! I've attached spec sheets below....
View attachment 293889View attachment 293890
Basically you can run any 2 stroke oil. High viscosity oils can be used at 40:1 and low viscosity oils can be run at 32:1 or 25:1.
I'd discontinue using the tcw3 marine oil. Many years ago I unknowingly used marine 2 stroke and after a couple of seasons after pulling the spark plug the piston top was fairly carboned up. With my Stihl it's had vp racing synthetic and Stihl 2 stroke oil for 5 seasons and the piston top looks remarkably clean.So I have been feeding a steady diet of 50:1 Pennzoil Marine Premium Plus 2-Cycle Synthetic Blend Oil into my Weed trimmers, chainsaws and backpack blowers for a number of years now without anything bad happening...
That helps alot. 2 stroke equipment that idles alot tends to carbon up the spark arrestor and whatnot.My weed trimmer gets used for the duration of about 1.5 - 2 full tanks of fuel at almost wide open throttle when I need to trim a large hill in my backyard that is too steep to mow. My backpack blower is used about the same when the fall hits and the leaves are dropping.
There has been no shortage of long term wide open throttle RPM use on any of my equipment.
