BrianWC,
Could a HDEO like Delo or Rotella clean off that sludge if you used it for the next 50,000 miles ??
This is in no way, shape, or form an argument to what you said about Mobil Clean. BUT, it's funny because according to Mobil, the Clean 5000 is good for 5000 miles OR the manufacturers recommended OCI, even if that is 10K. But I would think (and it's obvious you'd agree) if you have a turbo/oil raper than you'd want to NOT go over the 5K limit of Mobil Clean, even if 10K OCI's were recommened by the manufacturers..quote:
Originally posted by BrianWC:
No, I'll reserve that for Saab with their 10k oil changes in a turbo car which they were letting dealers put Mobil Clean as one option IIRC.
Nothing against MobilClean, just 10k intervals with it....![]()
I can't really say, but I just don't like the idea of buying oil online for some reason. Now that I think about it, it's silly really as I buy just about everything else online.quote:
Originally posted by vad:
Originally posted by Buford T. Justice:
Mobil 1 is easier to get especially when I am traveling.
You can order it online.
Get a case or a couple of cases that would last a looong time.
This availability argument doesn't really cut it anymore.
He's not bashing Mobil clean, he's bashing SAAB for specing 10K oci's in the first place. There's simply no oil that can withstand the abuse of these engines for 10k, least not with a 4 quart sump. They just acted like there wasn't a problem. They didn't even require synthetic for a long time, only semi-synthetic.quote:
Originally posted by bighead:
This is in no way, shape, or form an argument to what you said about Mobil Clean. BUT, it's funny because according to Mobil, the Clean 5000 is good for 5000 miles OR the manufacturers recommended OCI, even if that is 10K. But I would think (and it's obvious you'd agree) if you have a turbo/oil raper than you'd want to NOT go over the 5K limit of Mobil Clean, even if 10K OCI's were recommened by the manufacturers..![]()
Well, now I'm confused Vad. In my thread on how my engine was clean after 24,000 mi. on Mobil 1 you said:quote:
If the engine cleanliness is such a high priority for you, why woudn't you try Redline?quote:
Looks like a big difference between Raven's and Brian's engines. I am glad I am a Mobil 1 user now![]()
It will surely keep your engine clean (possibly the cleanest than any other oil).![]()
First of all, Redline is not "highly" expensive.quote:
Originally posted by jmacmaster:
So why are you now suggesting the highly expensive Redline to someone if engine cleanliness is a high priority for them, and telling them that Redline will possibly keep the engine cleaner than any other oil. You can't have it both ways.
Oh I know he wasn't bashing Mobil Clean 5000. It was more of me saying that Mobil should rethink their claims of it holding up to the manufacturers recommended OCI's, even if those were 10K in a turbo engine. So, basically I was bashing both Mobil and Saab at the same time LOL..quote:
You don't have to worry, your engine isn't one of the sludgers. The Trionic 5 engines have real piston rings and a proper oil pump. As for what oil, after reading a lot of UOA's on the saab 4 cyl turbo's it seems to me that a 40 weight is best for these engines. When I switched from 30 to 40 I noticed no change in mpg.quote:
Originally posted by Corrado:
I have a (new to me) 98 Saab 9000 with the 2.3L high-output turbo engine and about 105K miles.
For the first oil change, I went with Mobil 1 5W-30. I may try the M1 5W-30 EP next time, or even get a 5W-40 formulation like T&SUV. (Or even Rotella T synthetic).
From what I understand, my engine is not one of the ones prone to sludge - although I'm not 100% when the sludgy ones were produced (early 2000s I guess)
Not to highjack this thread, but does my oil choice sound good?
I'm looking to get maximum MPGs, and the car is driven pretty normally (not very hard on the car at all) I'll only put on about 6K miles a year.
My 170K-mile '92 B234T is on Mobil1 0W-40 right now, burns basically nothing, UOA was good, but I'm expecting to go to the Rotella T Synthetic next time.quote:
Originally posted by axjohn:
Corrado,
I have basically the same engine in my 900S without the turbo, and the car absolutely LOVES Delvac 5w-40 and Rotella 5w-40. I was pleasantly surprised by the Rotella, actually.
Corrado,
