Under valve cover pics - 06 Toyota matrix
socal
I replaced the valve cover gasket on this vehicle at 171K miles July 2022. Here are the pics:
Its now been approx 60K miles at 231K total miles and I decided to replace the valve cover gasket as I got a free gasket from a friend who found one in his garage that he had for his corolla that he sold years ago. What I expected to see with my OCIs was it not getting any cleaner but also not any darker / worse than before. Here are my OCIs since 171K miles.
171K Havoline high mileage 5w30, 4300 miles
176K Quaker State Full Synthetic 5W30, 4800 miles
181K M1 franjenbrew (5/30, 0/20, 15/50), 4300 miles
185K Quaker State Full Synthetic 5w30, 5000 miles
191K same, 5000 miles
196K Pennzoil Platinum 10W30, 5000 miles
201K same, 4800 miles
206K Havoline longlife 5W30, 4300 miles
210K Castrol Edge 10W30, 5000 miles
215K Valvoline Adv 5W30, 5400 miles
220K Castrol Edge 10W30, 4900 miles
225k Valvoline Adv 10/30, still in use at 5200 miles, will change the oil next week
Your thoughts
The lighting is different between the two sets of photos so it's hard to tell but I lean slightly towards it's a little cleaner now. You have been diving many miles each year and using good oils. Looks like varnish is very hard to remove. If you are driving a lot on the highway, I wouldn't change a thing other than perhaps extend the OCI a little. The varnish isn't going to hurt anything.
Looks good and clean!! A little patina at that age is to be expected. I agree, 2-4 changes of Valvoline Restore and Protect (VPR) is worth the investment. 6-8k OCI and let it do its thing.
Even 5k oci’s using full synthetic couldn’t keep the varnish at bay. On a side note the engine will probably run another 200k like that.
what's the makeup oil between changes?
My thoughts are, why not try and clean it up with Valvoline Restore and Protect or HPL? I'd feel more comfortable tripling the OCI into 15kmi intervals even though it wouldn't triple the cost
It does not consume, never added any oil between OCIs. I have a decent stash to use up so no need to buy HPL or Valvoline Restore and Protect. Think I may push the OCI to 6-7K
I don't think this received on time oil changes for the first 171k?
My sister's former 05 was a rental for the first 30K or so, then the second owner had a semi regular maintenance schedule....and it was much cleaner than yours at 130K:
I do a HDEO and 25% MMO run for 5k every other year. Not sure if it has anything to do with the cleanliness of the top end but something is working.
OP, keep doing what you are doing! You mention that you have a good stock of oil so no need for Valvoline Restore and Protect or HPL yet, but I vote adding a quart of HPL's EC-30 for each OCI, shooting for 5k OCI's. It will help clean that varnish over time.
