This report is from Oil Analyzers. It is a friends car that drives 140 mile round trip a day back and forth to Fort Bragg from home. Country roads most of the way in. The oil filter was a Wix. It has been using coolant and so I figured I would take a sample. It has 134k miles on the vehicle. This was the second oil change with Peak conventional 10w-30. Looks like there is a leak, not sure if it is the intake on this particular model or the heads. The sump holds 4.8 qts
Code:
Suggest INSPECTING COLLING SYSTEM (head gasket, heads, seals, EGR gaskets, etc.) for leaks. Coolant indicators (Sodium and /or Potassium) are at a SIGNIFICANT LEVEL. Viscosity is MODERATELY HIGH: Lubricant and filter change acknowledged. OIL Peak 10w-30 MILES IN USE 4,134 MILES 134,454 SAMPLE TAKEN 6/22/14 ALUMINUM 2 CHROMIUM 0 IRON 9 COPPER 4 LEAD 3 TIN 0 MOLYBDENUM 15 NICKEL 0 MANGANESE 0 SILVER 0 TITANIUM 0 POTASSIUM 63 BORON 8 SILICON 13 SODIUM 335 CALCIUM 2015 MAGNESIUM 13 PHOSPHORUS 846 ZINC 885 BARIUM 0 INSOLUBLES 0.1 WATER 0.0 Oxidation 10 SUS VIS 210ºF cSt @ 212ºF 13.5 Fuel% 0 Antifreeze% see comments TBN 3.81 Nitration 9
