mrbreezeet1
Thread starter
- Joined
- Aug 4, 2021
- Messages
- 1,366
Good Job! Thanks, Yeah, I've used the GM reusable gaskets a few times!You do not need a new tube just the Sonnax retainer, I would replace the gasket and accumulator seals. The ATP should be okay to use, you can reuse the original gasket, it is rubber coated steel and better than a rubber or fiber replacement.
I did a write up years ago, it may help, there is a link to the magnet pdf.
https://bobistheoilguy.com/forums/threads/pan-drop-or-fluid-through-dipstick.291305/page-2
