G Grumpy87 Joined Mar 24, 2026 Messages 1 Mar 24, 2026 #1 Had rough idle and P0445, changed purge valve. Now I'm getting P0449, vent valve soleniod. Did changing the purge valve have anything to do with the P0449 I'm now getting? 2009 Impala 3.5.
OilStained Joined Jun 11, 2024 Messages 842 Location 85633V7F+4Q Mar 26, 2026 #2 Both codes are generally the same.
C chemman Joined Feb 19, 2007 Messages 843 Location Maryland Mar 26, 2026 #3 Remember, Diagnostic Test Codes tell you there is a problem with a system or a circuit. They do not tell you that a part is defective. Diagnose the problem and then repair what is broken. It could be as simple as a broken wire or a bad ground.
