The Boeing 767 incorporates an inflatable slide at the inboard rear of each wing to allow the evacuation of passengers who use the over-wing exits during an emergency. Slide deployment is initiated by opening the exit hatch from the inside. The hatch opening motion actuates electrical switches that simultaneously (1) operate a relay to ground out any position command going to the main hydraulic spoiler power controller actuator, and (2) fire the spoiler override actuator which rotates the inboard spoiler to the down position. After a two-second time delay (from the spoiler actuator firing), the latch opening actuator is fired. The latch opening actuator opens the escape slide compartment door latches and fires the door opening actuators located in the escape slide compartment. The slide compartment door, with the escape slide packboard assembly attached, is rotated outboard by the actuators. When the door opens, a mechanical link to a high pressure inflation cylinder triggers the release of gas that inflates the slide.
