Oversized filter for PH7317?
Kentucky
Does anyone know if there is a larger filter with equivalent specs for the PH7317? (sorry, Fram part number is the only one I have).
My Frontier has the 3.3L V6, but Nissan gave it a whopping 3.7 qt sump, with filter. The filter is the same as they use on the Mitsubishi 4G63 and many other 4 cyl engines, it's one of the smallest I've seen.
Something a bit larger would certainly be beneficial in this application.
Check these out, same thread and gasket, may vary in can size (from another thread):
Let me see if I can do better. For 20 x 1.5mm threads, 14 psi by-pass valve, anti-drain back valve, 2.3" O.D. gasket 2.5" to 3.5" long.
about 2.5 inches long.
AC Delco PF1237
Baldwin B1400
Firestone TF2876
Hastings LF113
NAPA Gold 1365
Purolator L14612
STP S-02876
WalMart SuperTech ST6607
WIX 51365
about 3.25 inches long.
AC Delco PF-2057
Auto Pro 2356
Autopride CF240AP
Baldwin B1402
Carquest 85356
Carquest Red B4620
Casite CF240
Castrol 7317
Champion Labs Ph2867
Defense Filters Dl7317
Deutsch D-370
Federated Filters LF240F
Fram Double Guard DG7317
Fram PH7317
Fram Tough Guard TG7317
Fram Xtra Guard XG7317
Group 7 V4610
Group 7 V4620
Hastings LF240
Mighty M4612
Motorcraft Long Life FL-821
Napa FIL1356
Napa Gold 1356
Parts Plus PH2867
Pennzoil PZ-109
Penske 7317
Powerflo SL14610
Powerflo SL14620
Pro Gauge PGO-4620
Pro Tec 164
Promotive PH4610
Pronto PO3593A
Purolator L14610
Service Champ OF-4622
Shell SH48
Shell SH529
Stp S-02867.
Valvoline VO50
Warner PH2867
Wix 51356
That's a great list but 2.5 list actually is smaller than the 7317/14610 app(s).
The 3.5 list is the same size as the 7317/144610.
I was trying to give the OP an "oversize" application of the 7317.
PL/L14459 for the Purolator and it looks like 3593A using a Fram number.
Part Number: 51381
UPC Number: 765809513815
Principal Application: Chrysler (83-93), Eagle (89-93), Hyundai (86-89), Isuzu (81-85), Mahindra Tractors, Mazda (89-90), Mitsubishi (83-96), Renault (84-87)
All Applications
Style: Spin-On Lube Filter
Service: Lube
Type: Full Flow
Media: Paper
Height: 3.141
Outer Diameter Top: 3.660
Outer Diameter Bottom: Closed
Thread Size: 20X1.5 MM
By-Pass Valve Setting-PSI: 13-19
Anti-Drain Back Valve: Yes
Burst Pressure-PSI: 275
Max Flow Rate: 9-11 GPM
Nominal Micron Rating: 21
Gasket Diameters
Number O.D. I.D. Thk.
Attached 2.834 2.462 0.200
Close Window
PH3950, STP SO3950, PF 1177, Pronto PO 4619
Originally Posted By: sayjac
PL/L14459 for the Purolator ...
I see you already linked the Honda Civic thread earlier in this thread, but wanted to add here that the Purolator 14459 has a slightly larger volume (and probably media surface area) than the 14610, and the 14459 also has a higher efficiency than the 14610. If the 0.45" larger can diameter fits on the engine's mounting base without any physical issues then the 14459 would be the better filter to use IMO. I'm going to try one on my V6 Altima (VQ35 engine).
Here's the three filters numbers that are basically interchangable. Pretty close size wise in any case.
The 3593A holds slightly more oil (inside volume).
7317:
3.47" ht
2.69" dia
3593A:
3.36" ht
3.02" dia
6607:
2.67" ht
2.84" dia
Kind of an old thread - but I've used the Baldwin B1431 in place of the 7317 filters. Same specs as their B1400 and B1402 except the B1431 is 4" long.
