This engine uses a common 3/4-16 thread filter that has a not atypical 2.7/2.4 gasket. It's a 3"+/- diameter can and appears to have a common bypass valve setting.
Part Number: 51348
UPC Number: 765809513488
Principal Application: Various Chrysler/Jeep (82-09), Various GM, Saturn (85-07), Lexus (90-09), Saab (67-09), Suzuki (86-02), Toyota (88-09), Ford (03-09), Mazda, Mercury (05-09), Yugo (86-89), Harley-Davidson, Various Lawn&Garden, Farm Equip.
All Applications
Style: Spin-On Lube Filter
Service: Lube
Type: Full Flow
Media: Paper
Height: 3.404
Outer Diameter Top: 2.921
Outer Diameter Bottom: Closed
Thread Size: 3/4-16
By-Pass Valve Setting-PSI: 8-11
Anti-Drain Back Valve: Yes
Beta Ratio: 2/20=21/37
Burst Pressure-PSI: 275
Max Flow Rate: 7-9 GPM
Nominal Micron Rating: 21
Gasket Diameters
Number O.D. I.D. Thk.
Attached 2.734 2.430 0.226
Your options are only limited by your dimensional limits in diameter and length.
That is, you can go longer only or wider only ..or both.
What are your dimensional restrictions?
51515 (long and wide)
51068 (wide and slightly longer)
51516 (long)
..and many more..
