Oversize Filter Cross Reference
Nope, never seen one. Never seen an official one by the manufacturers either. Reason, they are not going to point out a larger filter that doesn't meet OEM specs. If one is interested in oversize, a little research is required.
Originally Posted By: oilchangeguy
does anyone know if there is a cross reference sheet to list oversize filters and the OEM filter it replaces?
This should help you out quite a bit:
http://www.tundrasolutions.com/forums/at...rscrossref2.pdf
Use that in conjunction with the specs at http://www.wixfilters.com/filterlookup/index.asp to ensure you perfectly match up the thread size and By pass valve setting PSI. Diameters will be different on oversize filters and you will need to do more research to see what will work for your application without problems.
