Oversized PL14459
SE Pa
If anyone has a part # I'm looking for an oversized Kia or Hyundai filter.
Is there any place where I could cross reference by size?
TIA
I think that is the big one
Wix makes one that's .39" longer ..the 51334
Purolator's own site cannot find a PL14459 (P-One)...it will find a L14459 (PP)
Write Bryan (or Brian ..they're both there) at fleetfilter.com. He has a master catalog that will tell him EVERY filter that Wix makes in that thread. He can then go by gasket size ..etc..etc.
I believe the new Bosch 3320 has same gasket size but is larger than 14459, and is now made by purolator. AutoZone has them. Same size as Mobil 1 M1-105.
Wix 51347, NAPA Gold 1347
zoom
Part Number: 51347
UPC Number: 765809513471
Principal Application: Ford Courier (72-82), Hyster, Komatsu, Merc. Bobcat (75-79), Pinto (75-79), Thermo-King, Yanmar Excavators
All Applications
Style: Spin-On Lube Filter
Service: Lube
Type: Full Flow
Media: Paper
Height: 4.828
Outer Diameter Top: 2.921
Outer Diameter Bottom: Closed
Thread Size: 20X1.5 MM
By-Pass Valve Setting-PSI: 8-11
Anti-Drain Back Valve: Yes
Burst Pressure-PSI: 325
Max Flow Rate: 9-11 GPM
Nominal Micro Rating: 20
