If you don't think a tailwind makes a big difference
What if I told you there was no wind today?
There are so many things to factor in it's probably a combination of several things. Even with my driving routes and habits being nearly identical from one tank of gas to the next it's not at all uncommon to see 2-5 MPG variation from one tank of gas to the next with the same oil in the crankcase. The only way to get a good baseline for MPG is checking mileage over several thousand miles and tanks of gas. There are certain routes that I drive on every tank that gets much better mileage than other routes simply because of roads/traffic/terrain. The Versa on my trip to/from church (approx. 15 miles each way) is probably lucky to get 45 MPG in warm weather yet, the trip to my mom's house approximately 20 miles each way) I wouldn't be surprised to see 60+ MPG and by the way I run 15 year old 10w40 conventional. I never check short distances I always reset the Ultra Gauge at the beginning of each tank and keep a fuel log of overall mileage since I purchased the car in 2/19. Years ago I drove from Statesville, NC-Nashville, TN quite often on I-40. One section of I-40 was concrete the rest was asphalt mileage was much better on the concrete section. Another thing to consider is if you're using a factory MPG readout they're often very optimistic. My Versa has a factory MPG readout and I have a calibrated Ultra Gauge. The Ultra Gauge is usually within 1 MPG of actual mileage the factory gauge is often 5-7 MPG optimistic.What if I told you there was no wind today?
Well, after "99.9", mine goes to "--.-". So, I have THAT going for me. B-)
I wouldn't be a bit surprised if PP is a "more slippery" oil
HUH? Sealing of what? The rings? If true, wouldn't that increase friction and REDUCE mileage?And if you've gotten 60 miles per gallon from using 0w-20 Pennzoil Platinum then I am sure that amsoil or red line 0w-20 will give even more and better as they have better material for better sealing.
Needless to say too, I myself don't trust the cluster mpg reading, they can be wildly decieving.I hate to burst your bubble but the general consensus is to get an average overall MPG that they suggest 100 miles of driving. If you're getting better gas mileage it could be from using a thinner oil or a lot of tailwind pushing you along. Again you're going to need a get around a hundred miles of driving and then that will give you a true or at least better accurate number on your miles per gallon
So you're able to control all of this in everyday driving so you can positively attribute an observed MPG change to one isolated variable?I also notice better MPG's when using it even over an entire OCI and not just short trips like you've done.
As to the Prius, why is over 60 MPG a surprise?
Yes sir, each and every variable is controlled on my work commute. Florida is a very stable climateSo you're able to control all of this in everyday driving so you can positively attribute an observed MPG change to one isolated variable?
- Tire pressure
- Tire alignment
- Engine temperature
- Acceleration/braking pattern
- Percent short trips
- Idling time
- Gasoline BTU variations
- Engine condition/maintenance
- Road type & conditions
- Aerodynamic drag
- Air conditioning usage
- Seasonal gas formulations
- Air temperature
- Air humidity
- Gasoline temperature
- Tire type
- Consistency of fill
- Altitude changes
- Vehicle weight
- Computer MPG accuracy
- Octane rating/accuracy
- Hilly terrain
- Air filter condition
- Traffic jams
Or likewise the comparative values that members post here.About as believable as the MPG ratings from manufacturers on new cars huh...
Will somebody wants told me that a lot of times they will use a thinner oil than what they even claim to be using and or using non-ethanol fuels to gain the highest miles per gallonOr likewise the comparative values that members post here.
Don’t leave us in suspense: which oil and filter were you using?My instant fuel economy meter said that I was getting 99.9 MPG when I was coasting downhill one day and none of you will ever beat that!
That’s what matters: that you are happy with it. I have no idea if the PP affected your mpg, but it’s obviously a quality oil, so if you like it, keep using it!But whatever, I love how the PP makes my engine purr so smoothly.
You just like the idea it made the engine purr.That’s what matters: that you are happy with it. I have no idea if the PP affected your mpg, but it’s obviously a quality oil, so if you like it, keep using it!
