Originally Posted By: Or
Originally Posted By: tombo
Given that OEM tires seem to last only about 28-30K for many people, that would equate to 7K - 7.5K per rotation. On the other hand, if one bought a set of tires that was expected to last, say, 50K miles, the ideal rotation frequency would be 12.5K miles. Is there a flaw in my logic?
Ginormous flaw is disregarding the different physics at each corner and how it influences relative wear rate. Starting a wear pattern and not correcting it before it goes too far is what this thinking leads to. The "carrot" analogy above by
raytsengwas brilliant. Every few thousand is optimal, and varies by tire type and vehicle. No set rule.
Unless your car is perfectly corner balanced at all times, there will be uneven wear due to different loads on each tire.
On Acuras, I find the right front always has the most wear, then the left front, then the right rear, and the left rear sees almost no wear. The right front is the corner with the engine.
With the same size tires at every corner, I always rotate front to back and cross to the front, and do it every oil change on my own car, which is every 6000 km.
On the 1er, it is staggered, so I rotate the tires left to right every oil change, also every 6000 km.
You want to change the direction of the tire as the leading edge of the tread wears faster than the trailing edge on the drive tires. You want to even out that wear as much as possible. Also, if the tires remain too long on the rear, they will develop scalloping on the inside edge, especially if the rear is loaded with cargo or passengers.
The more they are rotated the better.
