So I have a 2006 Toyota 4Runner V6 1GR-FE. I recently purchased it at 164K miles. So about two days after purchasing CEL P0016. So I took it to Toyota who said it needed a new chain tensioner but they had to replace everything chain wise to fix the problem because it was probably all worn out. So instead I took it back to the dealer I purchased it from, they took it apart and determined it did need a new timing chain kit and water pump. After the replacement no more CEL. I reset it a couple of times before heading to Toyota but it kept coming back on cold start. So the next step I check the oil and the dip stick is stained. Well I say stained more like oil that had gotten cooked on. It took a bit of scraping but I got that off. Next I looked into the oil cap, I mean there is minor sludge on the cap. I ended up changing the oil with pennzoil platinum 5w-30 hoping that will help. I just wanted opinions on what I'm in for. I had a mechanic check it out before purchase and the dealer fixed the problems he found. The timing chain was unexpected. I made sure they changed it because the old one I could see before the change through the oil filler area. The new one has a continuous blue line throughout the chain while it spins. But I can only see a small part of it. Could all this because of very poor maintenance? I've had it for over a month with no new problems.
