Originally Posted By: Anies
Originally Posted By: HK_Ace
Oh no, I hope she was at least using a good synthetic. Check the dipstick and oil-filler cap for varnish. You may use an oil that does a good job of cleaning the engine- one of the Pennzoils- like the Ultra. This would be a very interesting UOA to Blackstone...I'd do that too.
You never want to use a synthetic with a rotary engine from Mazda. It actually has to burn oil so it can lubricate the Apex seals in the engine. Synthetic is more resistance to burn off and there for causes a very high failure rate in their motors. Conventional or Mazda's specifically engineered blend can be used.
The burning of the oil has zero lubrication value. In fact, the longer the oil can resist burning is the more useful it can be as a seal lubricant. That said, "no synthetic in a rotary" is among the dumbest, most perpetuated nonsense since Pennzoil sludge. Ignoring the fact that for many years, Mazda and others have offered fully synthetic oils specifically for the rotary, it is in fact the polymers and additives added to oils that gunk up and buildup as deposits. So the great irony here is most people are shortening the lives of their engines only to satisfy their logical fallacies. Funny, and tragic.
Refeeding the OMP to a 2-stroke res is by far one of the smartest things any rotary owner can do. Being made for mass production and sold to many of the unwitting, using lube oil to do the job is the most 'no-brainer', easiest solution but barely adequate at best. *this is where people stop caring, but I'll say it anyway*: If I had to recommend a motor oil for rotary use, it would be straight, monograde HD30 mineral or synthetic. All lube points in the rotary are close together, with no cams, lifter, head or far off parts to lube and 'cold flow' properties mean zip. The only thing multigrading does is add extra chemicals that will only get in the way of clean burning, thermal stability, thermal capacity, and maintaining film strength. Truly understanding Rotary lube requirements really requires you to forget what you think you know about oil. Ideally, my rotary setup would certainly be a 2-stroke res to OMP, with Ester 10w30/SAE30 on the inside for longest life and happiest performance. Substitute 30 grade for 40 or even 50 in very high output applications, but always straight.
To the OP, your sister's engine won't blowup (it can't.. seriously, what is a rod bearing gonna go? tappets collapse?
rod get tossed?), but her seals are probably less than happy right now. At worse, she'll gradually lose compression. As for sludge, I can almost assure that there is a sufficient amount of fuel in that oil to prevent full and total gelling. 5w20 would get consumed the fastest as the fuel builds up in the oil and it's viscosity drops severely, and as (side) seals wear on, but it's not all bad as 5w20 minerals don't rely heavily on polymeric VIIs and thus less 'plastic' to melt and coagulate into hard deposits. At this point, 5w20 is very NOT ideal. All said though, the sequence of events is not totally tragic, but a little rough. Best of luck.
