Originally Posted By: tinmanSC
Originally Posted By: Spyder7
Well, she's getting new oil every 4K miles. The RX-8 (i think) only has a 4qt sump capacity. So it's had 25 quarts of oil through it. The filter is another story. Based on that rate of oil consumption, I bet this engine fared pretty well, all things considered. Of course, the rapid oil consumption may be due to the fact that it didn't get changes. 1Qt/1K is a lot, even for a rotory. But that prolly saved her engine, kinda killing two STONES with one BIRD on this one.
She says "she thinks" it uses about 1qt every 1k miles. Keep in mind she doesn't pop the hood unless she sees the oil level gauge light come on. Notice I said oil level gauge, not pressure gauge. The RX-8's come with a oil level gauge on the dash as they know the car will burn more than a quart between oil changes.
I wouldn't touch it. She's completely neglecting and abusing the engine. One oil change isn't going to prolong its life very long, and she'll learn the hard way when the light comes on just before it blows. Expensive lesson, but the only way it seems she'll learn it. Maybe then she'll take better care of her next car.
-Spyder
Yes, all of this is true. She totally screwed up and neglected that poor engine. Oh well, that's life. She added a quart of oil every 1K miles, which based on her mileage that's about a quart a month. That's pretty good, considering. Now, this is what she SAYS. But if it's true, i bet that engine will have some damage, but be OK. It might not live out the service life that it would have if it been properly maintained, but I really don't think it's going to go BOOM tomorrow.
The abuse of this engine will kill it by itself. The treatment, if continued, will be fatal. Why not change the treatment and hope for the best? Like i said, you're already dealing with a engine that is going to die if you do nothing. It's going to burn oil for the rest of it's life. Tough. Why not try and extend its life by giving it some resemblance of maintenance?
IMHO, get this thing on a normal maintenance schedule, and see what happens. It's not his fault, he's not gonna be paying for the damage. The worst that can happen is the appearance that changing the oil ruined the engine. If your engine is so far gone that changing the oil makes it go boom, then it was already toast. You just hadn't figured it out yet. Feel free to say I'm wrong, which I know people will, but the car only has 61K miles on it. This engine has a chance at staying in service of it gets maintenance, it doesn't have a chance if it's left to die.
Sorry for the long post, My neighbor didn't change the oil in his van for 2 years and 22K miles. We started the cleaning process 2 weeks ago.
Absolutely. The seller I bought my car off took better care of it than the average car owner, but being a burner with a clogged PCV valve, it was also sludged, so her maintenance schedule wasn't quite ideak. Was the engine damaged when I bought it at 96k km and took over the maintenance on it - possibly, but based on how its been running over the 10k km I've put on it since, it doesn't seem likely.
I have the sludge process in reversal, and some ideas about reducing the consumption. But once the engine's cleaned out, whether I succeed at reducing consumption or not, I expect this engine to provide many years of trouble free service. Part of the regular maintenance for me is checking the oil level frequently and carrying a quart in the trunk. If its down a quarter quart, I add that to bring it back up to full. I don't put off checking or adding oil when its below the full line, and this is why I expect it to last.
Consumption in and of itself is not harmful. Its only a problem when the owner doesn't stay on top of it and waits for the oil light to come on before realizing its time to top up. If she were to begin checking it frequently (at least every fillup) and add however much it needs to bring it up to full, do a reasonable OC now and then, and at least change the filter when it should be changed, this RX-8 could likewise live several more years. But for that to happen, the neglect has to stop and she has to start following the regimen an oil burner like this requires.
-Spyder
