Originally Posted by StevieC
As for engines imploding just past the junk points what I meant by this is that if the 20wt's were such wear causing oils the wear would make sure that the engines died shortly after the typical 200K mile junk point and that we just don't see that even well past 200K miles where 20's were used and that it would take a heck of a long time for this extra wear to be apparent making it essentially moot for the vast majority of users including the high mileage folks here on BITOG.
As a scientific discussion it's fine but it should be prefaced with how it affects the majority of drivers because there are varying levels of folks that read here and the way that Shannow is going about it makes it appear that using anything but the thicker weights is going to have terrible consequences when this just isn't the case, again for 99% of folks and even those high mileage folks here on BITOG. This just leads to the same style of argument that was here over a decade ago regarding using 20w50 instead of 30wt's because thicker is better and now it's 30's or 40's versus 20's.
I know you understand what I'm saying but I don't think Shannow does or he wouldn't be pushing his papers so hard when it's meaningless for the 99%
Shannow is an Engineer, and so his approach often assumes some fundamental understanding of science, math and perhaps basic engineering principles. If one wants to discuss the detail of these topics, then that approach is quite valid. If one is only interested in some cliff notes "run oil A" then a technical discussion shouldn't be where they decide to park themselves.
Per your introductory point, that's doing pretty much exactly what you are claiming Shannow is doing
Using hyperbole; exaggerating the phenomena to neutralize what one believes is being presented by the other side instead of discussing what's really being brought to the table. Acknowledging that an xW-20 allows for more wear doesn't mean that this wear is orders of magnitude more than an xW-30, to address your example specifically. We are dealing with progressive phenomena here which only present in certain conditions.
Engines wear, specifically, anything that is in boundary and mixed, you are simply trying to control the rate at which this occurs. In mixed, increased viscosity will reduce the amount of time that is spent in boundary. Just to toss out some hypothetical numbers, if you are experiencing say 20um of wear in 100,000 miles on the ramp area of cam-over-bucket setup with 5w-30 and that number becomes 25um of wear with 5w-20, making those our constants, you are at 40um/50um at 200,000, 60/75 at 300,000, 80/100 at 400,000 miles...etc. So as the mileage racks up the differential between the two, based on rate, grows. But this is small growth. Ergo, passing some mileage threshold established by the OEM isn't going to result in the engine dying. If the OEM's wear limit is 75um before replacement, we've reached it at 300,000 miles with the 5w-20. If it is 100um, we've reached it at 400,00 miles with 5w-20 but it would take to 500,000 to reach it with the 5w-30. Both could still be serviceable at that juncture, but we've crossed the OEM's wear limit, follow?
